I keep cracking rotors on my G car - suggestions?
#76
Originally Posted by 1957 356
I don't have to bleed after every session, but the pedal goes to the floor and I have to pump it back after every session when I get back in the car. I'll check in with Dan on the fluid. Maybe I have a problem in the system. I don't think it's my braking style, I've had many experienced instructors/racers in my car and it's never come up. On some of these track like LRP, I'm really not braking much at all (really only going into T1). I could switch from Motul to SRF but I didn't think it would make that much of a difference - the boiling points aren't that different.
Trust me on the SRF. It does make a big difference when compared to Motul, especially if you are right on the edge of boiling the fluid, which seems to always be the case with our SCs. You will bleed half as often.
Cheers,
Jeff
#79
NASA Racer
Originally Posted by JimmiLew
I used to run super blue in my car, and never had a problem. What kind of brake fluid are you using?
#80
NASA Racer
Originally Posted by Gary R.
Never had a problem using SB, pedal always good and firm. Sure sounds like air in the lines to me..
I'm starting to think that as well. I'll have Dan take a look at the system. He's going to have the car for a couple of weeks in August.
#81
NASA Racer
Originally Posted by jaydubya
My car does the same thing (pedal is soft until pumped up). I think its the rotors cooling and/or the fluid boiling in the pits.
Cheers,
Jeff
Cheers,
Jeff
#82
Cheers,
Jeff
Cheers,
Jeff
You guys should listen to GWTurboS & Analopg Mike, Stock SC rotors are undersized but the best available. Concetrate on ducting as much air in to them as you can and run at minimum weight. SRF may keep the fluid from boiling but the rest of the parts will still run too hot and as a result won't last long.
#88
Jeff, what causes pad knockback?
http://www.stoptech.com/tech_info/wp_knockback.shtml
I love this quote about one way to reduce pad knockback:
"5. Slow down and reduce cornering forces
Naturally, this solution is no fun and is not recommended"
#89
If you have a 911, 964 0r 993 w/ stock components w/ pad knockback you have bigger problems than addressed here.
FWIW I met a guy at the track that had huge Stoptech brakes on a new ZO6 vette with increased HP, running slicks, and he had a knockback problem.
#90
I'm cheating The Man for a couple of minutes while I post this from my office, but this is where all our material specifications books are located and I cannot take them home.
This rotor cracking subject peaks my curiousity based on the category of Why Stuff Breaks. If you are not interested in material specifications, skip this post. This is merely an observation on materials used for passenger car rotors versus what is good for thermal cracking resistance.
My list of gray iron casting grades per SAE J431 says that there are 3 common materials: G7/ASTM A48-20, G9/ASTM A48M-25, and G10/ASTM A48M-30. G9 and G10 have higher Brinnel hardness ratings and lower graphite content, so they tend to wear longer. This makes them popular material specs for replacement brake rotors. However, G7 has higher graphite content and higher thermal conductivity, so it has greater thermal cracking resistance. Unfortunately what I am finding out is that G7 is more commonly used for casting brake drums, not discs.
This makes a little more sense now. The typical aftermarket supplier/manufacturer is dealing with a customer base that is more concerned about wear, not thermal cracking.
I'm jumping back into my regular job right now before I get fired, , but I just spotted a great graph of material tensile strength versus temperature. When I get a moment free, I will post a quick summary as a follow-up.
