Momentum => mantaining more speed in through the corner
Originally Posted by paradisenb
I attended a DE at Barber this past weekend. Randy Pobst and Ian Bass gave chalk talks for an hour Saturday and Sunday. I asked Randy a similar guestion, "How do I get faster" he/they responded with hit your apexes and focus on exit speed. Coming out of a corner is where most lap time improvements can be found.
I also did a few hot laps with Randy. He was driving a 550 HP 997TT. He did a 1:40 taking it relatively easy. Hard out of the corners, threshold braking and constantly negotiating the slip angle near the limit. Not your typical Sunday droven.
Randy I looked around for you some over the weekend and never saw your car.
Were you in the car in your avatar?
Originally Posted by 1957 356
At what point in the corner are you back to full throttle most of the time? After the apex, at the apex, before the apex? Do you have to feather the throttle or do you go on full when you get back to it?
brake
then almost immediately back on the throttle
then i ease on the throttle to rotate the car
then I am on full B4 the apex.
What am i doing wrong? What can I do to increase my exit speed?
When I screw up the above is when I get onto the throttle too much and I need to ease more than I wanted creating a too abrupt weight transfer. This makes the rear come around too much and I lose speed.
Originally Posted by Doug H
I know what you are getting at. A good instructor could help you here. My students are almost always braking too much for corner entry or turn in. I initially give them marks for braking, off, and maintenance throttle. I know by feel what is a safe speed and I am constantly telling them brake, off (brakes), and throttle in most corners. At first, they are hesitant about the off when I say it because it is hotter than what they are used to. I also get them off early enough to get the car balanced and on a maintenance throttle at turn in.
Once they trust me, they get the feel of driving a balanced car with speed through turn in to the apex. At apex, it is all about feel of the car's yaw and slip angle, feel of fronts through steering wheel, and just knowing by feel when the car will accept without creating too much understeer.
You cannot learn any of this here. You will have to develop a feel for this stuff. A good instructor and advanced car control can help expedite the process.
What you don't want to do is get on then back off the throttle. The idea is to set up the apex then roll on the throttle once and stay full power to the next brake point.
Originally Posted by mamoroso
At this particular turn I was referring to I:
brake
brake
ps. Matteo, what events are you doing in the coming months? I am sure we will be at some of the same events and I would be happy to take you out (if possible) to illustrate some of this.
Dell
I am in the process of moving to the UK. My family is already there. The only thing holding me back is the completion of the 811 project (in my signature).
I signed up for the PCA DE at Loewes. If I am still here4 I will do NASA at CMP on 7/13. Is there anything around here on 7/7?
I'd love to go out with you. My instructor is on the waiting list for Loewes. He's great!
I'll be instructing at Lowe's but not sure how much can be shown there. It is a weak infield followed by pretty much the entire D oval. Should be fun but nothing I am going to take a 10/10th.
CMP is a fantastic track. My favorite for technical instruction and learning. If you are still going to the Lowe's event swing by. I am in the yellow GT3 #210.
This past weekend, I had a student with 40 track days and the maintenance throttle was a novel concept to him. At first, he would accellerate when getting back on the throttle which I could feel and he could not. After a couple of sessions, it all clicked. He then learned how to balance and steer or change the slip angle with the throttle. He also began to feel, without me telling him, when the car was rotating or coming around so he could accellerate hard at just the right the right time.
You have to pay attention to the car and be smooth. The car will tell you where the perfect line is so to speak. Very minor adjustments in the the throttle will keep the line optimal without forcing the car with the steering wheel and allow you to maintain a line through a corner without altering your steering input to the apex. Otherwise, you will likely be just scrubbing off speed by inducing understeer and maintaining a bad slip angle or preventing proper rotation at or before the apex which will allow you to maximize your exit speed. Hard to explain, but very easy to show someone what it feels like on the track. The difference is accelerating when the car is ready as opposed to when you think your should be.
brake
brake
I even do full on split second lifts sometimes to get the car to rotate in hair pins or carousels if I am really hot. This is quicker than allowing understeer to scrub the speed and allows me to get the proper slip angle or yaw to maximize acceleration as early as possible.
This is the map of the track. It is run anti-clock wise.
The turn I was concentrating on is turn 5-6. Some people do a double apex there...
I was taking a very late single apex staying all out on the left...
I would finish my braking before turn in, mantain throttle up to when I wanted to rotate the car, then then blip the throttle for a split second and rotate b4 apex. If everything went as planned then full on throttle, apex, track out.
Turn 3-4 were perfect for trail braking in my opinion... so that you could single apex it (late). I was not good at that though. I was coming into turn 3 at around 120mph and I was not smooth enough in the transition between brake and throttle and I ended up over-rotating the car...
So I concentrated in getting my braking done before turn in and then hit my apex etc... but very aware I was braking way too much.
Here I think that my mistake when trail braking was braking too late with the same force, whilst I should have started at the same point but braking less.
Turn 7 was a throw away corner.
I experimented with turn 8-9 between a late and medium apex... Turn 9 puts u onto the bank and my car preferred a medium apex using the bank to rotate again at full throttle.
I am rambling here and I am really treasuring all the comments you guys have mad. I wish I could go out again tomorrow....
Again I will reiterate what I said. Having listened to what you are writing, I think you need to learn car control skills before increasing entry speed. There is alot of technique involved in getting the car to make it to the apex when carrying more speed and more chance of losing control. Trust me when I say that if you get more seat time, the speed will come. If you really want to gain speed fast, hire a professional coach. Most instructors will only get you to learn the basics and keep you safe.
Check this out (physics of racing series)
http://www.miata.net/sport/Physics/Part17.html
I occasionally do data for our race team and I feel it is the most common problem. It requires restraint not to pick the habbit of too much speed on entry.
regards
regards
For single apex, I would use a quick threshold and then maintenance throttle. If the car is not rotating or the car is understeering at or near the middle of the carousel, do not add more throttle. You are too hot. Speed will scrub if you do nothing, but you can decrease the radius, get the car to rotate and get on the gas even sooner if you decrese throttle slightly until you feel the shift. Pay attention, be patient, and you will feel the car settle and come around.
Very nice. I will print it out and read it carefully.
Mitch I hear you, and I agree with you. I am not trying to skip steps. I just want to correct any type of mistake early.
You guys have all more experience.
If you say "Matteo you are doing everything right, keep your head down, keep doing what you are doing, don't experiment and you'll see how little by little your exit corner speed will increase as a consequence of refining you car control skills. You'll really reach the limits of the car with time and you'll look back and realize how far you were from the limits on exit.
When that happens you'll be ready to maximize the entry speed"....
...then I am OK with that... I just want to make sure that I am not starting with the wrong foot.
Cheers!
Cheers!
This was EXACTLY what I was doing. And I was pretty consistent as i developed a good feel for the car and my exit speed was always close to the same mark.
I was always trying to reduce the radius by lifting a little rather than let the car understeer if I was too hot.
HA! so double apexing would have been the way to go eh? Next time then! Thanks for the clear explanation!
