Cordless impact wrench
Old 06-09-2007, 11:55 PM
RickBetterley
RickBetterley's Avatar
Originally Posted by joel-cs
With the Sears model @ 180 ft lbs - does it OVERtorque the lugnuts when putting them on? Or do you not put them full tight and then use a torque wrench after?
The latter; I use the wrench to break loose and remove the nuts, then when putting them back on, use my fingers to thread, spin them up with the wrench, then hand torque once the wheels kiss the ground enough to keep from spinning.
Sounds like more work than it is.
Old 06-10-2007, 12:20 AM
rickdm
rickdm's Avatar
Guys, thank you for the suggestions, I am glad to hear there are some good choices.
Toby, thanks for the offer, could you bring it by the house sometime?
rickdm
Old 06-10-2007, 08:50 AM
Brian A.
Brian A.'s Avatar
Originally Posted by RickBetterley
Sears 180 ft lbs;
Which Sears model is 180 ft lbs? Looking on their website I found a 19.2 volt model (#11483) but the specs says 900 in lbs which to me sounds like 75 ft lbs.
Old 06-10-2007, 09:05 AM
DrJupeman
DrJupeman's Avatar
28V Milwaukee is what I use...
Old 06-10-2007, 10:14 AM
speedread
speedread's Avatar
Originally Posted by tyro
Fellow Rennlister and friend F1rocks uses a Milwaukee 18V impact:
http://www.thetoolwarehouse.net/shop/MLW-907922.html
Kicks a$$..err..seems to do the job nicely.
I have no trouble with the battery, (try discharging the battery and charging again, as it works to take off and put on tires several times with rain, etc.); and it puts them back on at almost exactly the right torque, so just a click or two tightens them up correctly.
Old 06-10-2007, 10:33 AM
mnorek
mnorek's Avatar
+1
I use this one as well--this impact wrench does it all and has Lithium ion batteries (powerful and no "memory" effect).
Old 06-10-2007, 10:53 AM
OriginalSterm
OriginalSterm's Avatar
24V Goodyear and I wish I bought it sooner
Old 06-10-2007, 11:13 AM
lawjdc
lawjdc's Avatar
Me too - highly recommended
Old 06-10-2007, 11:48 AM
Bill911
Bill911's Avatar
Longacre 24 volt. Reasonably priced, works great!!!
Old 06-10-2007, 12:08 PM
smlporsche
smlporsche's Avatar
Here you go...
http://www.sears.com/sr/javasr/produ...&subcat=Drills
Old 06-10-2007, 12:56 PM
PogueMoHone
PogueMoHone's Avatar
Check this package out, it is the latest and greatest 18v from Makita:
http://www.tri-statetools.com/maklxt...63afa8b5e2b19e
Old 06-10-2007, 02:34 PM
jford
jford's Avatar
+1 on the Goodyear from Manny Moe and Jack. 24 volt, less than $80 US dollars and spins them off with the car in the air...Just used it an hour ago, in case anyone here doubted the effectivness of this tool.
Jamie
Old 06-10-2007, 04:10 PM
Brian P
Brian P's Avatar
I use the 18V Milwaukee and wish they had a 24V when I bought it. That being said, I also have the 18V Milwaukee cordless drill, so I'm chock full of batteries.
Old 06-10-2007, 06:37 PM
JackOlsen
JackOlsen's Avatar
For all of you who now have more foot pounds in your impact wrench than you want on your lug nuts, takes a look at a a torque stick to keep yourself from over-torqueing (and potentially ruining alloy nuts, or damaging studs).
Old 06-11-2007, 12:18 AM
Kerry
Kerry's Avatar
Yep, torquestick is what I use.
Quick Reply: Cordless impact wrench
