HP Brake Pads & Vibration Dampers
Do you guys use the Vibration Dampers with HP Pads? I'm installing Hawk Blues on the Boxster S. I have the Glue/Tape on Dampers with the ends that fit inside the pistons. Should I use these with the Hawk pads? What is the glue/tape that I should use?
TIA
Randy
TIA
Randy
No, too much of a PITA. BTW, The Blue 9012s will work well, but I think you would like the performance, life and rotor friendliness of the Hawk HT-10s better.
Thanks Bob. Appreciate the help and the tip on the HT-10s. This is my first set of HP pads so I'm feeling my way throught the process. My not enen stay with Hawks.
Agree with Bull on both his suggestions. BTW don't leave the Blue pads on for street droving. You will destroy the finish on the rims if they get wet. PS. I may have a full set of Boxster S rotors with about 500 street miles on them should you be interested.
