Stock vs. Pagid Orange vs. ???
Seems the yellow and orange pads I use now don't squeak on the street after installing new for a week or 2. And after they start squealing like a stuck pig, a track day will mellow them out again on the street for a week or 2. I might get a lot of crap for agreeing w/ you, but I thought the stock pads were quite decent too other than wear. I haven't tracked more than half worn street pads though. Bring both. So easy to change it might be somewhat moot. But guess it really depends on how you are using them at the track.
Still plays with cars.
Dan - when they start to squeal, re-bed the pads - or go to the track!
My experience was completely different, my Pagid Yellows squealed proudly!
Originally Posted by lwilkins
I had the same experience--my Pagid Oranges squealled a LOT (emarassingly) on the street. Replaced them with OEM and the squealling stopped, with no other changes.
Don't you guys find that changing pads with those "anti-vibraton pads" a pain? I've removed the brake pads sensors to make it easier, but loosening these from the rears seem to take forever. Any solutions?
I am not sure there is any really good compromise pad out there. I run Pagid Blacks on my Carrera 3.2 and Hawk HPS+ on my Miata. They both squeal about the same. I have just bought a set of PFC '01 and 97's for the Carrera. Some folks tell me they will be much quieter than the Blacks other say the opposite, I think it just depends on your specific calipers and rotors. I don't think any of them will be as quiet as the OEM pads.
rickdm
rickdm
Just found this old post and wanted to add to it. I just had Pagid yellow RS29's put on. These are the newer yellows. The fronts do not squeal but the rears will squeal going slowly in stop and go traffic...actually they kind of howl instead of squeal.
I have ran the oranges on the street and track for years (used to switch back and forth also) I have found if the oranges are "properly" bedded in they make minimal noise on the street.
The howl/squeal/noise is a bit dependable on how the discs and pads are worn, how long since bedding, how warm they are, any glazing, cracks and so on... It's not really a pad made for street driving, rather to be warmed up and then continuous beating with endurable performance.
I'm using pagid 19's (yellow) on the front and 14's (black) on the rear and squeal around town is really acceptable. So far, I have probably 12 DE days on them with minimal wear.
Rear's not much of an issue - how many running hours do you have on twelve DE?
RS29 (almost the same as RS19) can go up to 12 running hours on a cup car during endurance, a bit depending on track of course. Not really comparable to 12 DE, but quite impressive at least.
Moderator
Not impressed with Oranges. After 2 DEs they are pretty much toast. Although only 50% worn, they are crackled up and I'm concerned they will disintegrate. Granted, one of the DEs was Cups & Saucers (about 6.5 hours driving in 2 days), and the other was a regular DE but my son shared the car -- so double duty. Both at Watkins Glen. Lots of pad deposit, caustic dust... I'd go PFC 97 as Farnbacher suggested to me.
Moderator
Trust me, I properly cared for the pads (bed-in, warm up, progressive increase over a couple of laps) -- they just couldn't hold up to the punishment. I have the GT3 cooling ducts and control arms for camber and was running RA1s on Fikse 13s. Lap times for me in the 2:17 range first day at WGI (street tires) and then +/- 2:13 next time and my son was running 2:30. He was easy on the brakes, but I pushed them hard.
