Cool shirt alternatives
Originally Posted by ngoldrich
I like the shirt without the hood better for fit - so I was going to try the cool shirt sans hood with the electric air conditioner LOL...
http://www.hrpworld.com/index.cfm?fo...action=product
From our experience, the cool shirt systems offer about 3.5 hours of cooling time IF you put mostly ice in the chest and just enough water to run thru the tubing. The ice melts during the 3-4 hour period buy stays cooler longer. Still a pain to track down ice every morning but not as expensive as a refrigration system built into the car. Cool Shirt also recommends using a large block of ice with some ice cubes around it and a little water - the block ice takes much longer to melt that crushed ice. They also offer a 24 quart system which offers about 6 hours of cooling time but the cooler is larger so space may be an issue.
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
ApexPerformance.net
I'm with Apex. I fill my cooler with ice to the max and then add water. I may or may not have to add a little more ice for the last run dependng on the heat that day.
Keeping the torso cool is great, but the head is like a radiator because it's so vascular. Keeping it cool might help as well (but I don't think I could find a helmet big enough for all the tubing and my head...).
Formula One Spin Doctor
When I checked into what NASCAR uses this is what I found:
http://koolboxproducts.com/index.php...pr=Shop_Online
I think I will get one and try it in the near future..
Norm
Norm
At those prices , i would need your wallet to keep that cool norm .
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Cool shirt makes an air & water system that runs about $1000 bucks and you use in conjunction with a forced air helmet to cool the head. More pricey but probably still less than a refrigerant system.
I am currently using the cool shirt system with the helmet blower. When the ice is good, it is great but keeping ice in the cooler is a bit of a hassle. I was hoping for a simple solution but I guess I'll stick to what I have.
FAST has carbon-X shirts, which I like. CoolShirt has Nomex available.
The down side is they they use different hose connectors, so if you have a Brand shirt but get into a car with Brand B gear, you need to buy adapters (ask me how I know).
http://www.hrpworld.com/index.cfm?fo...cat_id=849,587
You have to request what type of nomex shirt you want from Cool Shirt - CarbonX, Gforce, Stand 21, Firewear, etc. I've seen all of these and they are great. You can also send your own nomex shirt to them and they will have the tubing sewn on for you - I think it runs about $100 for the service but if you already invested in the shirt and plan on using a cool shirt system a lot, it may be worth it versus buying another brand new shirt with the tubing which can run about $200.
Almost forgot - cool shirt does sell the form for the block ice that fits in the cooler. You can also use empty cardboard milk jugs filled with water and freeze them. Then peel off the cardboard and stick the block ice in your cooler. We have the block ice form on our website but the shipping is probably more than the product itself. http://www.apexperformance.net/cartg...t.asp?scat=308
