Breaking in shaved RA1's
You read that wrong.
Start 34/36 cold when new
After that start 34/32 cold to achieve 40 psi hot.
Personally I run 32 cold to achieve 38-39 hot and I have never started with different pressure new or used.
You guys need probe pyrometers to ascertain where your starting pressures should be. I have different starting pressures on different corners for different tracks/configurations, all based on using a pyrometer.
Originally Posted by 171mph
34 at front when hot? interesting. I have a cayman s and run 38 front/back when hot (pretty evenly balanced rear/front). do you find 34 at front causing understeer at all?
Cold start pressures required to achieve a specific hot pressure varies by the car and the suspension set-up in my experience. As Dave said, a pyrometer is required, and a durometer is good to have also.
