Kumho V710 tire pressures
Anyone have suggestions? I started off with the same hot pressures that I use for the Hoosier R6, and those numbers are consistent with the (large) range that Tire Rack suggests, but perhaps I'm off a bit.
I went out on a set of Hoosier R6s with about 15 heat cycles this past weekend and replaced them in the next session with a new set of Kumho V710s. Sizes were slightly different:
Hoosier
224-45-17 front
245-50-17 rear
Kumho
225-50-16 front
265-45-16 rear
I ran 36 psi front and 34 psi rear hot in both tires. The Kumho V710s were noticably slower with less grip than the Hoosier R6s. Also turn-in was not as sharp with the V710s and they were generally less communicative.
Camber is -2.5 front -3 rear.
Cheers,
Jeff
Hoosier
224-45-17 front
245-50-17 rear
Kumho
225-50-16 front
265-45-16 rear
Cheers,
Jeff
Thanks for your response Joe.
My car is 2450 lbs with 1/4 tank, 2670 lbs with me in it.
Should I try lower than 34/36 hot?
Curious if you have any firsthand experience with comparing the V710 to R6... should I expect comparable grip or is what I have experienced expected?
Cheers,
Jeff
Cheers,
Jeff
Originally Posted by mm86911
I ran 38 hot all fours in March and rand within .5 secs of R6s same pressures.
Which were slower?
What does your car weigh?
Cheers,
Jeff
Originally Posted by Joe Weinstein
A pyrometer should do better than our speculations...
Joe
Joe
However a data point from you would be helpful nonetheless...
Will changes to my car setup, tire pressures and driving style for the 710s result in equivalent performance to the R6 or are the 710s just slower?
Cheers,
Jeff
Originally Posted by jaydubya
Same day?
Which were slower?
Cheers,
Jeff
Which were slower?
Cheers,
Jeff
Same day within 2 hours and 5 degree ambient temp variance. Car weighs 2740 with driver and 7 gallons fuel. (PCA E stock). The Kumhos were faster but you know driving can easily vary that much. As for the R6's I find they are great out of the gate but fall off faster. The Kumhos come on slower but maintain grip longer - I would definitely use the Kumhos for enduro. Same setup for both tires and temps with 10-15F swept across each tire in hot pits.
Your car weight with driver is very close to mine.
Once I have some more time on them I'll post further impressions...
I've been running 710's for a couple of years and through my own experience and that of guys who run in the T1 series, the 710's like the mid 30's hot. I start out in the mid 20's (~25) cold in my Z06 and they'll get to ~34 when they peak out. I know one guy who starts the rears out in the teens, and he's a nationally ranked racer.
A tire pyrometer is the ultimate answer.
