Trailer - Electric Brakes NOT Working!
I was setting up my trailer for the first time since I got it. Measured the tongue weight at 475#, so that was good.
The problem is that when I turned on the Prodigy Controller, it kept displaying that there was NO TRAILER hooked up! After a lot of troubleshooting with a digital ammeter, I determined that all of the connections on the trailer are "hot", I even get all of the lights, signals and brake lights working on the trailer.
On my '06 Explorer with the Class III/IV hookup, the 7 pin connector has power to all but 2 connectors, with (1) being the electric brake circuit. I've tried the circuit with and without the Prodigy, both to no avail.
Any additional thoughts to troubleshoot: 1) the Explorer wiring, 2) the Prodigy, 3) the electric brakes (I pulled the disconnect pin, and voltage from the trailer battery was present to the trailer brake circuit).
Originally Posted by Big6Dad
When you pulled the pin, did the electric brakes work? If they did not work, then I would guess it is the brakes themselves that are the problem.
Originally Posted by amondc
I think that fords have seperate fuses for the trailer connectors. Check the fuse block under the hood and there should be one for trailer brakes there.
Chris
Chris
A question........won't the brakes work (full on) if a brake controller is NOT used? I ask, because I don't get any power (voltage) at the trailer brake wiring with the brake applied.
Basic Site Sponsor
Basic Site Sponsor
Lou, it sounds like your trailer wiring is in order. Since you can operate the brakes with the emergency battery, try doing so with a battery charger from the trailer plug (both the power feed and the ground point). That would totally eliminate the trailer. I would then verify the integrity of the electric brake conductor (from the controller to the plug socket) and the ground connection. If that is ok, then it's time to question the brake controller itself.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Ground - OK - ohm check
Power - OK - 12V
Brake input - OK - 12V when brake is depressed
Brake output - OK - put 12V to line and read Voltage at rear connector plug
Looks like a bad controller! Will the trailer brakes work WITHOUT a controller?
Basic Site Sponsor
Basic Site Sponsor
the rate of retardation
...........spoken by the expert on the subject!!
