First time trailering
Originally Posted by Mark Dreyer
Also, any tips on RA? Ive done probably 8-10 DE days total, all at Sebring, Moroso and Roebling Road. This will be my first trip to RA. I'm in the blue group, still with an instructor.
Originally Posted by Chuck Price
RamVa,
Why do you recommend only crossing the straps at one end?
The reason is that under heavy brake there can be a high longitudinal load, and if all four straps are crossed the straps have less leverage in arresting it. So long as the steering is locked it is sufficient to only cross at one end, as lateral loads are generally going to be far, far less than braking loads.
A couple other things I should have mentioned: 1) For some trailers 911s have to go on backward to get sufficient tongue weight, and 2) put the parking brake on but do not put the car in gear.
before, but never with a car on it. Any problem going highway speeds, or should I keep the pace down a bit? There's no hurry, I'm taking an entire 2 days extra for travel days between Orlando and Atlanta.
You've gotten some good advice on this thread. Take it easy and you'll get there ok. You'll find RA quite a contrast to Sebring, Moroso and RR: the elevation changes are a blast. It's a terrific track. Have a great time.
RamVa,
I think I understand your reasoning, but have never heard that before. I have always crossed both ends. Also, I have never used my parking brake or put the car in gear. That is what the manufacturers of Trailex recommend, and so that is what I have always done, both with open and enclosed trailers, although that should make no difference. Fortunately, I've not yet had to test the advantages of this set up.
Yet another thing I didn't mention - assuming you're strapping down by the wheels, make sure the line of the strap is on line with the hub/center of the wheel (or close). That way when you tighten it down or when the strap pulls it won't be trying to rotate the wheel.
look for me at the track! silver 996 towed w/ a tan suburban. looking forward to the event as well! last year's was pretty crazy but this year should be even better. maybe we should organize a porsche corral in the paddock.
btw the drive from orlando to atlanta is 8 hours or so.
Originally Posted by 1957 356
spend some quality time in a parking lot practicing backing up. You'd be surprised how hard it is if you try it for the first time without practicing. Small steering inputs add up to big trailer movements. I just started towing with the same truck and an open trailer and it's a really good combo. You'll forget you're even towing.
Also, I would stop after about 30 minutes of towing and check all of your straps, just to make sure everything is nice and tight. Once you get your system down, this might be a moot point, but I still do it, just to be safe.
Have a blast.
Originally Posted by RamVA
Crossing both ends isn't fatal, but I wouldn't do it. You wouldn't want to be in a situation where you test it. As for the parking brake, I can't think of a good reason not to use it but I'm open to hearing one.
Originally Posted by smlporsche
Once you get your trailer leveled you might want to get some woden blocks to put under the very end of the trailer when you unload to keep the ramps from rising.
Enjoy.
A Porsche corral sounds like a great idea. Is there a place we should meet and park our trailers? I have never been there.
And my friends VW
Feel free to come by and say hi
Chuck, this is my first out of region audio club event. I wanted to go to Barber last year (along with Mt Tremblant and Mid Ohio) but it just didnt work out. The timing was right for this since Ill be at VIR mon and tuesday which isnt really all that out of the way. Ive been looking forward to this for months!
