SFI approved fire suit 3.2A/1 or higher - sources
Most reasonable sources for:
SFI fire suit rated 3.2A/1 or higher.
neck collar, gloves and shoes.
totally new to this - don't need the most durable as will be limited use, but need to meet safety on a budget.
sugestions - experiences with manufacturers appreciated
Found a super budget set - suit/shoes/collar/gloves <$200
Not sure the route I will go but sharing for anybody else in the market
http://www.speedwaymotors.com/p/6325...uit-Combo.html
Documenter of Ineptitude
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you are looking for a cheaper suit. You could always check G-force outlet store.
http://www.gforceoutlet.com/
Cows-4-Rent
If you're looking for budget items, you really don't need the neck collar. Also consider that the lower priced suit are usually much heavier than higher quality. Running in the midwest in July and August you'll be wishing you ponied up a bit more $$ for a good suit. They can last a long time (mine is 6 or 7 years old) so the annual cost isn't all that much.
