Is 5W-30 Oil OK for the Track (Cold Weather)?
Agent Orange
I'm taking my car to Lime Rock at the end of the month for a DE event with PDA. I'm currently running 5W-30 oil and it looks like the high temp for the day will be around 50F. Am I OK with this set up, or should I change the oil? This is for a 91 Carrera 4. Thanks!
Super Moderator
Needs More Cowbell
Needs More Cowbell
I would have thought that 15W-50 would be fine at that temperature, but 5W-40 or 0W-40 is also an approved viscosity isn't it?
Yes, I know, another oil viscosity rennlist discussion...time to hide in the bunker and wait for it ot end.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by ilko
I didn't know it was discussed so much. Maybe one of the mods can create a sticky at the top and then everybody will have it as a reference.
I've run 15W-50 at LRP in March, it's a bit 'thick' during crank but once you're up to temp and running on track, it's fine.
FWIW, I run 15W-40W in my wife's Excursion Powerstroke this time of year and it's OK.
Super Moderator
Needs More Cowbell
Needs More Cowbell
As a reference for 5W-40 and 0W-40 and FWIW :
http://www.wrightune.co.uk/downloads/approved_oils.pdf
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by sjanes
I'm switching to synthetic diesel oil for my 911 now that Mobil 1 has changed from API SL to API SM.
Originally Posted by ltc
You're baiting him, aren't you?
It's been discussed on the 911 boards of Pelican and Rennlist with a lot of debate.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by DJF1
http://www.mobil1.com/USA-English/Mo...1_15W-50_.aspx
The new Mobil 1, hopefully the old staff...keep fingers crossed!
How are we supposed to tell if the 'new M1 15W-50' is the same as the 'old'?
