Is 5W-30 Oil OK for the Track (Cold Weather)?
The symbol on the back of the container will say either "API SL" (old stuff) or "API SM" (new stuff). At least that's the way it's displayed here in Canada.
Super Moderator
Needs More Cowbell
Needs More Cowbell
OK, so if I have this straight....
The 'original' Mobil 1 15W-50, fully synthetic, yadayada, had a RED cap....the oil I've always used in the 964 and is currently stored in the basement after cleaning out WalMart a while back.
The 'newest' Mobil 1 15W-50 has a silver cap and is as good as the original red cap. It is SM/SL rated.
http://www.mobil1.com/USA-English/Mo...1_15W-50_.aspx
The 'other' Mobil 1 (extended performance)15-50W has a gold cap, is SL rated and is NOT the stuff to use as it's SM rated.
http://www.mobil1.com/USA-English/Mo...ce_15W-50.aspx
OK, I surrender.
OK, I surrender.
I'm still confused myself. In the Canadian market, it appears they pulled the 15W50 in favor of the 5W50 around the same time this change was made.
For more info see:
https://rennlist.com/forums/showthre...ight=EOS+15W50
http://forums.pelicanparts.com/showt...0&pagenumber=1
For more info see:
to add to the confusion they are reintroducing Mobil1 15-50 with higher ZDDP levels.
http://www.mobil1.com/USA-English/Mo...AQs.aspx#FAQs3
Super Moderator
Needs More Cowbell
Needs More Cowbell
So, the simplest thing to do is just rebuild your engine rather than change the oil.
