For INSTRUCTORS/RACERS of 951's at VIR
My question is how are you getting thru T-16.
My approach thus far has been to brake in a straight line, feed power turn left and stabilize power down the hill into turn 17. This does allow me to be on boost thru T-17 A getting 4th at track out coming up the hill on the front straight. So what I might have lost going into 16 I more than gained coming out of T17-A being well in the power.
My thought is: is there anything to be gained by trail-braking thru 16 and can it be done? I have not wanted to attempt it thus far. I am aware the rear engined cars will take this approach. However for our cars, they don't like to be on the brakes hard at high speed and attempting a turn. Also the initial turn in is down hill and off camber (probably further kicking the rear out) with a considerable erosion and drop off from the track surface. I didn't try it at last visit, but in reviewing tape last week it had me wondering.
Basic Site Sponsor
Basic Site Sponsor
You have to brake up to the compression bump in 17; it is the limiting factor for Hog Pen. Therefore, IMHO I think that the best way is to go as deep as possible into 16 and brake through it up to 17, wait for the compression, and get on the power. Of course, I'll know better on Friday.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Huh. Missed this thread earlier. I concur with Larry. Also, ren, you don't have to be at high speed & turning. What you wanna do, IMHO, is to slightly trailbrake...and concurrent with you rolling off the brake pedal, roll on the gas at the same time to spool up your turbo. This will really help squat the rear of your car & reduce any tendency to oversteer there.
Totally agree with Larry and VR. I am not driving a 951 but I am sure the process is similar. I go as deep as possible into 16 which almost forces me to trailbrake into 17 which really helps with rotation going through hogpen. Even with all that I still can't be fast enought o use ALL THE TRACK on exit of hogpen coming into the top of the front straigh (17a). One of the days.........
I turn in late and trailbrake the heck out of the first left, get on the throttle for just a sec, then brake a bit between 16 and 17, and then get on the throttle hard just a bit before the compression referenced above and ride a slight yaw angle all the way to track out where the track catches the car. While not in a 951, it is a front engined car.
Originally Posted by RSRRacer
Should be on or near full power just before compression/bump. This is in a fairly high HP car but not a 951
In my S2 which is somewhat similar to a 951 I take it one of two ways (I'll be testing these this weekend now that my suspension is fully set up.)
I tap the brakes just enough to set the front end going into 16 and apply moderate throttle through the short straight. I apply more throttle just after turn into 17 so that by the compression bump I'm at full throttle. This puts me at redline at track out comming onto the straight. With the turbo transmission you won't be at redline which should allow you to shift into 4th after the car starts down the front straight.
The latest way I've tried it is to shift up to 4th between 16 and 17. I'm at the lower end off the torque sweet spot for my car but this allows me to actually carry more speed through 17 and 17a and not have to worry about shifting at track out. It also gets me to 5th about 100 yds earlier comming down the front straight...so I guess this might be the faster line.
for what it's worth here is a lap I ran in 05 - dry line has just emerged late in qualifying. In the last section I run in 4th. Quite often I find I'm quicker runing i a higher gear even if I have to wait a few milli-seconds for boost. IE avoid 2 shifts and concentrate on best line, entry speed and throttle application
http://members.rennlist.com/bill935k...best%20lap.wmv
Trailbraking into 16 certainly helps to rotate the dumbell car. If you have the left-foot sensitivity (I don't yet), you can LFB before turning into 17A to keep the turbo spooled. You should certainly have the hammer down (no lifting) before the compression area.
Try it a few different ways and use your RPM at the start/finish line to determine which is faster for you.
Now that is just a silly amount of power!
Back to 17A -B
I never feel I am getting back to the throttle early enough 17A, I'm working on my left foot and this is definitly a corner IMHO that needs it to setup the entry right and have the power available at the right moment
Basic Site Sponsor
Basic Site Sponsor
I really think that part of the "proper technique" depends on your car, your HP and the stiffness of the suspension. The only car that I have driven at VIR was my GT3, which had lots of power and a relatively soft suspension. That car would compress, rebound, and then settle. If you tried to accelerate at full power through there when it was on the rebound, the back would step out bigtime.
I'm thinking that the RSA with it's stiffer suspension and less power should allow me to be more aggressive through there.
