Brake Scoop/Duct Help Needed
I recently dropped an aluminum front brake duct (scoop type that attaches to control arm) off of my 93 RSA and am trying to locate a replacement (knocked off and run over at the track). Although I have checked with a number of suppliers (AJUSA, Performance Products), my scoop/duct has a two inch diameter barrel (portion of scoop/duct which attaches to flexible hose which runs to rotor) and the scoops/ducts that these suppliers have two and a half inch diameter.
Please let me know of any suppliers of brake ducts so I can contact them or if you have an extra duct. Thanks in advance, Adam.
Technical Specialist
Lifetime Member
Lifetime Member
Good luck. I believe both OG Racing and Weltmeister stopped making their kits. However, if you find one that is 2 1/2", you can buy adaptors to take that down to 2" to mate up with your existing hose.
Thanks for all the helpful suggestions.
I ended up using a duct with a 2.5 inch barrel. I inserted my existing ducting it into the barrel (rather than over it), wired it on and duct taped it. Not the best solution, but it seemed to work at a PCA DE event this past weekend. I’m headed to an open track day on Saturday at Homestead and will be monitoring the duct tape seal.
Best regards, Adam.
93 RS America
Best regards, Adam.
93 RS America
