BBS RS..?
Posted on the tire/wheel forum also.
What type of socket is needed for the fasteners that hold the center in the wheel. There are about 4 dozen of them around the inner lip. Want to remove them to refinish and also need any tips on the removal. These I believe are 3pc. but recently discovered they may be 2pc...? BBS RS Mid 80's honeycomb style w/huge center cap. I never have seen a starpoint on an external bolt before so question if/what socket I need.
tia!
tia!
I see, another simple issue solved! Had me puzzled for sure, was aware of the male but not the female version, go figure, women have to be included too huh! Torx....man what ever happened to the days of wrenches and sockets and nuts and bolts!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
old skooler....
Thanks Bryan!
old skooler....
Thanks Bryan!
If they're the standard ones that are on their racing wheels, you can just use a standard 12 point point socket which you can get from any Sears hardware. ...I forget the size off the top of my head. Torque spec I believe is 100-120 inch pounds. Maybe someone else can confirm.
Torque specifications are 100-120 inch pounds, you sir are correct JoeMag.
Same goes for the 8mm 12 point.
Just confirming what's already posted.
Steve Ed
Steve Ed
Good job all, thanks! Any pattern to tightening?
And just to confirm the above confirmation that is already posted....can someone confirm this please?!
Dallas,
I like to start at the valve stem and then go 180 degrees across and snug them to 100 all the way around. And like everything else, check your work and increase the torque wrecnh to 120 on the final pass.
Are you making it down to Sebring?
Steve Ed
Steve Ed
Steve...I will know as soon as I get out from under this beast they call the 924S!
I decided to go the full monty and turn this 20 year old car and powerplant into a new one.
