Hoosier tire size question
#32
Originally Posted by bgiere
Ok, looking forward to the "Cup Car Reunion at Mid-Ohio '08"!
#35
The set up I used with the hoosiers was 225"s on the front. You don't need 245's on the front.The difference is only a 1/2 inch and its better aerodynamically. The 225's in the front will help reduce understeer. The rears you can run 275's
Make sure you role front and rear fenders and you may need spacers on the rears
#37
tire sizes
225s reduce understeer? 245 should help reduce understeer. I guess it goes to show everyone likes there setup a little differently. How would a smaller front tire reduce understeer? If you want to reduce unersteer consider the larger front tire.
#38
Basic Site Sponsor
Basic Site Sponsor
Maybe the 225 works better on an 8" wheel than the 245s. I am running the 245s on 9" wheels.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#41
I am going to run the 225/40/17 and 275/40/17 Hoosier on 7 and 9s for the first time in a few weeks
1. Does I need to change the stock springs to run them?
2. Can I change the spring to Something like turbos(reds) without changing my shocks for now.(Budget)
3. If I need spacers in the rear, what is the standard size needed, (SO I can get them ordered and on the way)
#42
This is true ,the front rim size(8's) are better suited for the 225.Also less tire role.It worked well for me.The 225's are also a little less money.
More grip on the front wheels means more understeer to me.The reality is you can make sway bar adjustments to compensate for under/oversteer.
Try them both and see what you like.
my 2 cents
my 2 cents
#43
I think you're on the right track to be asking questions (obviously since that's what I've done here). Hopefully someone with stock springs will come on and address that with first hand knowledge. Personally, I try to to re-create the wheel (pun intended) when it comes to questions like tire fitment ... it's a lot easier and cheaper to just ask questions. But you'll have to do some trial and error in all likelihood. Also, you might consider calling Bob Woodman who I have found very helpful and knowledgeable.
Hope some of this helps.
#44
Basic Site Sponsor
Basic Site Sponsor
Don't forget about solid bushings. You cannot run these wide tires without them. I have about 1/4" of space to the outside fender lip, and they don't rub, ever. Stock springs+stock shocks+stock fenders=narrow tires.
#45
for the best advice on Hoosiers ,call hoosier tire east..860-646-9646 Brian is the man!!He can give you set up info and pressures etc.I have done a lot of testing with them over the years, a very good guy, and very helpful .
