What is cornering effect on front and rear track width?
If the track width of front and rear are different, what is the effect on cornering? For instance, is it better to have front and rear wheels with the same track width or rear wheels furthur out than fronts?
The farther out the rears are than the font would usually cause more of an understeering issue. There is a delicate balance to be had depending on the weight distribution of your car and types of corners you'll be running along with tires you'll be using.
