window net mounting help
Old 12-26-2006 | 01:49 PM
spazegun2213's Avatar
spazegun2213
Default window net mounting help
Alright guys,
I'm going to be installing a net on my 944 spec/cup car and I was wondering how you all mounted them to your car?
I have the buckle figured out (i think) but the rear mount for the net I'm a little stumped on. So I'm looking for ideas on how to do this.
thanks guys!
Old 12-26-2006 | 02:24 PM
JackOlsen's Avatar
JackOlsen
Do you have a cage? Usually, you attach it to tabs welded to your cage.
Old 12-26-2006 | 02:27 PM
spazegun2213
I have a cage, and i guess i could have something welded on, but I'm looking for where its welded.
I just looking for ideas right now.
Old 12-26-2006 | 02:48 PM
spazegun2213
https://rennlist.com/forums/showthre...ght=window+net
i guess it would be better if i searched a little more
but is there someone mounting the net another way?
Old 12-26-2006 | 03:26 PM
Dave in Chicago's Avatar
Dave in Chicago
Mine is strapped to the bottom part of cage, spring-loaded into welded tabs on the top...
Old 12-26-2006 | 04:16 PM
spazegun2213
Dave,
I noticed a little gap between the net and the cage where the cage bends and the net does not. Does that pass tech? I assume it would, but just make sure.
thanks!
Old 12-26-2006 | 04:41 PM
Cory M's Avatar
Cory M
Be careful with your placement of tabs and latches so you don't smack your head on them climbing in/out of the car.
Old 12-26-2006 | 06:33 PM
bgiere's Avatar
bgiere
+1 on avoiding scalping yourself with the tabs....it hurts.
Old 12-26-2006 | 06:38 PM
Dave in Chicago
Originally Posted by spazegun2213
Dave,
thanks!
Yup, no issues. The cage-builder recommended/installed and it works fine. I can clip the net up fully suited/strapped with HANS.
The little gap at the front allows a small beverage pass through during pit stops and/or a friendly point to screaming Cup cars
Old 12-26-2006 | 08:14 PM
mjensen's Avatar
mjensen
I had some similar issues/concerns last season with my 944 turbo. A rennlister recommended a Schrotch window net kit, net buckle, clamp-on tabs and two web straps. I like the set up. If you are looking for a weld-on unit, Dave @ Adavanced-Autosports.com has a great weld-on kit and the net angle matches most nascar driver's doors.
Old 12-27-2006 | 03:00 AM
Cory M's Avatar
Cory M
Most of the universal kits are crap. I bought and returned the Autopower kit and just ended up making my own brackets and tabs. The Schroth kit looks like one of the better ones. I like the ones with spring loaded rods that slide into place. It seems like most window net set-ups I see at the track are compromises and don't fit very well, probably just due to the fact that there are so many different cage and doorbar designs..
Quick Reply: window net mounting help
