Which best mod to reduce 2' my lap times ?
I've got a standart GT3 with Roland Kussumauls settings.
Only for theoric purposes, let's asume that I am a great and experienced driver, a champion.
What would be the main mods in order to gain 2 seconds on a 1'52" technical ( only one evident straight ) track ?. I am no talking about feelings , just raw seconds.
In other words: which would be my next intelligent move to improve my CAR track efficiency ?
Going from less to more investment and from less to more efficiency this could be an example of short advise...:
A) Tyres
1.- DFOT aprouved 2.- Slicks
B) Suspension
1.- Settings ? 2.- Shocks ? 3.-
C ) Engine
1.- ECU 2.- LWFW ? 3.- Gear ratio ?
D) Brakes
THank you all for your advise.
( BTW this is not a theorical question for me, I really want to overtake this XFXDFDFX?! modified GT3 that is allways before me... )
A) Tyres
B) Suspension
C ) Engine
D) Brakes
In order of cost:
1) Drop the weight 300+ lbs (strip the interior, pull out the safety bumpers, remove passenger seat, etc)
2) Use slicks with the proper camber/caster/toe
3) Upgrade the suspension (1000/1200# springs, RSR links, etc)
Those changes could yield 4+ seconds.
The springs are stiff enough on a stock GT3 to run slicks, but if the slicks and re-alignment don't give you enough (and they should) your next step would be 3 way adjustable shocks and stiffer springs. There is no sense in going to say Motons ($$$$$) and not changing the springs too ($$). Forget about any motor or brake mods. You can't get much improvement from either in a GT3. If it is a point and squirt track, then shorter gears could also help, but that would certainly be a point of diminshing returns.
Of course weight reduction will make a big difference, but that starts you down a very different course. Stripped and gutted street GT3s aren't in big demand.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Originally Posted by boqueron
Thanks Larry. Nice to hear from you ! I surely will go for the re-alignment + slicks + suspension.
Any suggested non-Moton alternative ?
38D,
Thanks, any rough idea about the needed budget ??
2) Slicks are ~$1500 USD per set
3) To do a top suspension on a GT3 is north of $12k, maybe even more (RS uprights, motons, springs, links, etc). Ask Radomin (NJ-GT) on the GT3 board, as he has a good setup.
As Larry said, you could also gear the car specifically to the track you run. Also, having a pro pit crew that could setup the car to the specific track/conditions is probably worth 1-2 seconds alone (swapping springs, setting shocks, sways, etc).
Personally, I would just buy a cup car before modifying a street GT3. You are going to dump a ton of money and it will never be as good a the GT3 cup. If you are going to run slick you will have to trailer the car anyway, so get the right tool for the job.
Good point and one I am interested in at this moment.
If I take the JIC Cross Comp. suspension off and move to the Moton triple adjustable what spring rates would you recommend I move to?
