Anti-seize on lug nuts?
I attended a DE this past weekend and another driver was using anti-seize on his lug nuts...I've never seen this application. Is this recommended? Thanks ahead.
Porsche calls for their mechanics to apply a little, so it can't be all bad. I don't find it necessary on lug nuts that are on and off all of the time though.
I remember going to a DE at Taladega Gran Prix Raceway one time in January, after I had not changed tires since October.a I had to go to a Hardware store and buy one of those torches that you use in plumbing to heat the lug nuts so I could get them off. The stuff works, but as Bob W. says if you take your wheels off a lot, it is not necessary.
Bill Seifert
1987 944S Race Car
Bill Seifert
1987 944S Race Car
Originally Posted by DanS911
UMMM
only on the threads not on the shoulders I think
on the shoulders would change the torque value...no?
Antiseize minimizes galling when metal-to-metal surfaces rub under high load. Lug nut threads and shoulders qualify when they're tightened to 95 ft.lbs., then the alloy wheel expands from heat.
Since aluminum nuts and steel studs are dissimiliar metals, they will corrode and co-mingle molecules without antiseize between them. Removing locked-in-place lug nuts is something you want to avoid.
Sherwood
Sherwood
