Passing in the Braking Zone
#46
Originally Posted by renvagn
Mitch, I am in the NE (outside of Phila.) so do the cup cars run in that region?
#47
Since my DE ride is a set-up 951 S, I would probably not be thrilled with the slop and roll suspension of a stock 944. So it sounds like SP2 would be the place. Are all the cars relatively equal or is there a model (ultra-lite wt 944 na, 968, 944S2 or 951 which is better suited for the series? Thanks.
All 944 spec cars use the same 2.5L 8valve engine and run 2600lbs. 944 cup allows 3 different prep levels at different weights. They run tires from 15" to 18" in diameter and weight range from 2650 to 3000lbs all in the same class. Dave has done a nice job of balancing the prep levels, but it is not a spec class by any means.
944 spec was designed from the start for low cost, fun, equal racing of the 944 NA so there are no rules compromises.
#48
Body Roll comparison
Picture 1 look at the red/white 944 spec car
Compare to the heavily prepared E46
Same track, same corner. Both cars turing race laps. In the 944 this is flat out mid 3rd gear. In E46 this probaby not flat out, but the driver would be on the limit.
#49
SP1 cars are lot more equal, but are NOT softly sprung. If driven on the street they are so stiff as to be tolerable for only a short distance. A stock 944 NA suspension has several times the body roll of 944 spec car. Infact any street able 951 will be infact much softer than a properly built 944 spec. While we use 250 to 400lbs front springs the cars are some 700lbs ligther than my stock 951S.
#50
LMAO....right before the E46 M3's motor did this:
#51
Thanks Joe. So the specs are not like the stock F class pca club cars. Can you use camber plates?
#52
#53
So shocks, springs, bars, strut brace and camber plates can be used in SP1?????
Details & rules can be found here http://944spec.org
Now back to or regularly schedure TD schooling!
#55
Renvagnm,
944 Cup cars have the same basic rules as PCA I stock or H prepared - so springs/shocks are free. F cars run in the Supercup. Also, ITS prepped cars can run in cup with a small wieight penalty due to their increased hp level.
Cup runs primarily with Nasa in both the Northeast and Mid-atlantic - which means, watkins glen, mid-ohio, summit point, VIR, Beaverun among others. Typically you'll see 20-30 car fields at most races. As we're hijacking the hell out of this thread, PM me if you'd like.
