993 Rear Suspension Links Change
Originally Posted by 38D
They are legal, you just have to set them at the stock setting.
Colin, if I read your reply correctly, by just having the adjustable links on the car is not the issue but rather it's the settings of the links that determine whether they are legal, is that correct?
Originally Posted by TheOtherEric
That's interesting. What's the "stock" setting? Some 993's can barely get -1.5 deg camber, while others can somehow get -2.4 (me, for example) in a stock setup.
I would think the adjustable rears should be legal as long as there is no advantange over the stock pieces. If you can set them and "pin" them to a stock length, where's the beef? At that point, there is no difference between those and the adjustable camber plates up front.
Just my 2 cents which means I am probably wrong.
