AMB transponder (non-direct wire) battery replacement question
I gave my transponder to my buddy to use for a driver's school event only to find it never reaches a charged, usable state. My rechargeable transponder no longer gets a green light after about 5 days on the charger - it used to take about 2-3 days to get there. Before I go opening it up, is the unit powered by standard cells that can be purchased and replaced? I am curious of anyone has done this before and has some hints. Has anyone try to wire a rechargeable transponder direct from a 12V source on the car?
Does AMB do the battery replacement if I send it in, and for how much? I could not find that service info on their website - seems they'd rather sell you a new one!! My next race is in 2 weeks, so I need to do something to get this thing power! Thank you
Super Moderator
Needs More Cowbell
Needs More Cowbell
AMB will replace the battery, but the price varies depending on age, new style vs old style, etc.
As a short term fix in 2 weeks, could you run a wire from switched 12V to the transponder, in other words, run it as a hardwired unit?
Super Moderator
Needs More Cowbell
Needs More Cowbell
http://www.amb-it.com/pdf/forms/EUTr...er%20repair%22
However, if you should experience any problems with your AMB transponder, please send it to:
AMB America
Sales & Support
Operating Hours 09:00-17:30
Eastern Standard Time
AMB i.t. US Inc.
3200 Highlands Parkway Ste. 104
Smyrna, GA 30082
U.S.A
Telephone: +1 678 816 4000
Fax: +1 678 816 4001
E-mail:info@amb-us.com
*When sending in equipment for service, please include your contact information and a brief description of the problem.
AMB America
Sales & Support
AMB i.t. US Inc.
Smyrna, GA 30082
U.S.A
Last edited by ltc; 09-11-2006 at 09:25 AM. Reason: updated US office contact info
I was just reading the website posted by ltc and it says that the transponder if kept in the cradle when not in use, will maximize the life of the batteries.... hmmm, that might have helped
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by garrett376
I was just reading the website posted by ltc and it says that the transponder if kept in the cradle when not in use, will maximize the life of the batteries.... hmmm, that might have helped ![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
"! Charging Instructions !"
Do not charge the transponder longer than necessary for a full charge.
A full charge is indicated by a steady green LED
Fully charge and discharge the transponder once every three months.
Please refer to the manual for complete charging instructions
Wrongly charged transponders may void transponder warranty....USA
OK, so now I read the instructions:
Charging
Place the transponder in the charger. A flashing red light means the transponder is charging and a steady green light means it is fully charged after 14 hours. Charge the transponder at least every 3 months. Do not charge the transponder longer than necessary for a longer battery life.
garrett,
do your instructions for the 260 say the same thing?
Super Moderator
Needs More Cowbell
Needs More Cowbell
Emailed AMB USA in GA, here is the response (30 minutes...pretty good customer service):
The correct answer is that the transponder will go on "trickle charge," so you certainly don't have to remove the transponder from charge the instant it finishes charging (an extra 24 hours is fine, for example). However, we do not recommend leaving the charger all the time. That will shorten the overall life of the battery.
After about 4 years, my first AMB rechargeable TX stopped 'charging'. $90 to AMB and I got a replacement. Apparently there were some kind of issues with the lithium batteries used in TranX260's (I think that's the model) which contributed to long 'green flash' life (~5-7 days) but a short life overall. The new one will only give me ~3 days on a charge.
260, amb, batteries, battery, blinking, cells, cost, light, rechargable, red, replacement, replacing, transponder, transponders, tranx
