Battery Cutoff Pull Cable Routing
where have you guys with 964 or 993 cars been routing the battery cutoff pull cable ? I don't want to drill a hole in the cowl metal. Is there a really thin cable that can fit between the colw and hood ? thanks andy
I just used some thin, braided cable from Home Depot, along with some brass screw-on cable ties/stops. TO protect the paint, I put red heat shrink tubing over the cable. If I were really worreid about scratches, I'd fasten some Xpel clear bra material where the cables comes out. I haven't and it's fine.
Here's a post of my install - at the end is a pic with my pull cable:
https://rennlist.com/forums/964-forum/189368-mystery-solved-964-kill-switch-done-the-right-way.html
