"braking backwards"
#31
Originally Posted by M758
Not true at all. The brakes need to be release at the right time for that corner. That can be well after turn in depending on the type of corner. If you have stopped braking by turn in you will be giving up tons of speed to those still braking after turn in.
This to me is the heat of trail braking and no it is not a Novice technique.
I think what JPS is saying is that when at threshold, you must begin to release some brake pressure to turn in. Otherwise, you will loose control. Remember the friction circle. You must stay withing that circle.
#32
Yes, thanks. You ease off the brakes as you turn in... Ideally, you should keep the weight transfer on the outside front wheel absolutely identical through the transition from 100% brake to 100% cornering.
#33
I also use a form of the 'squeeze your student', but I do it (with their permission) as hand pressure on their right thigh as they brake. I find that my hand's varying pressure on their thigh is more 'connected' to the student's braking pressure.
Bill
#34
Lifetime Rennlist Member
Weight is always moving around (remember that weight transfer is not a function of body roll, it is a function of g loads) andour job as a driver is to manage that weight.
