Removing overspray from Lexan
Is there a good way to remove primer overspray from a lexan windscreen ? It's a fine dusting from nearby painting - not solid patches of paint. It looks like the windscreen is permantently dusty. Is there a polish or something we coudl use ?
There is a polish you can get at motorcycle stores (used on visors and windscreens), it comes in three stages in small plastic bottles. To remove your fine dusting, I would think the finest polishing stage would probably be enough. Your windscreen will come out looking better than before, once the primer comes off.
Thanks for the tips. Windscreen is coming off soon for extra bars to go in, so that will be a good time to try things.
I already have Scratch-X and the Meguiars polish and cleaner - would those work, or are they too agressive ?
Technical Guru
What type of primer are you dealing with? If its from a spray-can you could probably wipe it off with mineral spirits. What ever you do don't use acetone it will melt the lexan.
