Contain Yourselves - My Kirkey RR Deluxe Grows Up.
My take on the alloy seats is similar to Redline. In fact he was the one to convince me to buy it. I sold my OMP carbon 8lb shell for this 20lb aluminium seat that cost nearly the same as the carbon seat. Now that was painful! But I am glad I made the switch. The first thing I will say is that the fit of a custom seat is second to none. My butt feels now things I never felt before. You have to try custom to appreciate it and the Ultrashield is a custom seat. Pads in the carbon seat just could not get me as good a fit. So your mileage may vary on that one but man what a difference. If your butt feels more and you don't slide in the seat you go faster. Circle track guys have more issues with walls than road racers. Road racer barriers are more vaired. Circle guys have mostly concrete. They know something about containing drivers. I think GBaker will atest to the fact that the guys getting the most hurt are the circle guys. Composite seat makers just are not making containment as extreme as the metal guys. They can but they have not. I have sat in the viper racetech and the cobra seat and they are pretty good. Probably as good as we need in road race. Ther is a tradeoff between containment and egress. The more containment the more difficult the egress. I figure I have to survive the hit first before I have to egress so I chose containment. I understand but do not know this to be fact but believe the metal seats can be used without back brace and that plastic over a certain age needs back brace. Personally, I think that back brace is part of a proper safety system so i would use it in either case. Also plastic has spring and memory and I am not sure that is a good thing in an impact. I know metal deforms with no memory but if properly supported then this is not an issue. I also think that proper support is part of the safety system where the seat is actually connected to the cage not the car. Dual users just can't use a full containment seat for daily driving. It is too restrictive. So there is another compromise. From a practical standpoint the metal is the metal when you drill it and put bolts through it when you mount it. Plastic does not like that as much. Often times drilling holes and bolting plastic yield spider fractures in plastic unreinforced holes so you have to be a bit more careful when you drill and bolt it. In fact I don't think plastic manufactureres want you to bolt back braces to seats which further allows their whipping memory nature. metal seats you can securly fasten and just drill and bolt. I think metal can give you the most "tub like" feel and connection of seat to cage that you can get in a tintop.
Originally Posted by A.Wayne
1100 BUCKS FOR AN ALLOY SEAT !
Better include installation as part of that custom fit.
As Far as fabbing goes , doing composite mods are not a problem today as most now work with it , It is of course easier to find someone to weld , but it can be done with composites.
That's right , to run an alloy seat you need to add additional bracing that is not required , when using a composite seat. We have been looking at the alloy seat as an option but was put off by all the extra support necessary for acceptable installation.
Remember also it takes more time etc to get out of one an alloy seat in an emergency.
FBB made some other good points, like the cement walls the roundy round guys deal with. Also, sports car racers look at things like driver changes and such. Still, I think that the sports car crowd may have to suffer some fatalities like the NASCAR boys did before they are fully awakened. Looking at some of the in-car from Daytona... it was just scary how minimal some of their setups are.
Formula One Spin Doctor
EScuse me guy's ,
THe seat is for sitting the belts are for containment , depending on the seat or choosing a seat based on containment is incorrect ( can we say DaleE.)
The seat should support you in place as comfortable as you want , then you snug the belts for containment. Also the composite seats are proven safe and are tested and crashed tested to prove that via their FIA Seal , the alloy seats are not. I had looked at the alloy seat as a few associates had made the switch, but was put off by the fact of the xtra bracing and that the seat had no form of testing done on them.
In the event of a shunt the memory and flexing of the composite seat goes a long way in protecting you vs a rigid seat .
What about metal fatigue?
I always crack the Recaro side brackets after a year or so, and they are 5/6mm thick. What happens to these aluminum seats when you put a high mass driver (me) in a high G car?
Chris Cervelli
Premier Motorsports
Chris Cervelli
Premier Motorsports
EScuse me guy's ,
...If you are talking 1970's thinking. Things have come a ways since then. You're a bit behind the curve, my friend.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
I have no idea what the Earnhardt reference means.
Chris Cervelli
Premier Motorsports
Chris Cervelli
Premier Motorsports
I would say that the seat brackets see different stresses than the seat itself, and that is not a direct correlation between them. The brackets get ALL the load, in a concentrated area with no triangulation or spread of forces, rocking side to side, whereas the seat only sees partial loading in certain areas. What the backets attach to, and how, would have a lot to do with how the seat itself faired.
Of course you are quite correct that these things need to be checked, especially for us big'uns, but I'm not sure I'd be more comfortable in a plastic seat in that regard. Maybe the FIA thinks so too?
Originally Posted by RedlineMan
Absolutely 100% correct...
Hey All;
Here are the shoulder fences completed. The .095x3x.625 reinforcement is welded to the seat all the way around.
![](http://www.redlinerennsport.com/06SeatFencesDoneSide.jpg)
![](http://www.redlinerennsport.com/06SeatFencesDoneRear.jpg)
That sucker is STIFF!
That looks stiff. My question about metal fatigue was mostly about the bolt holes where the side brackets mount. I guess it has big plates there to prevent cracking?
Rearding plastic fatigue: I think composites are immune to fatigue because the fibers very effectively stop crack propagation. I haven't had any Recaro seat failures and I have tried!
I think John's solution works here but now this seat is $1500 and weighs 3X what a Recaro weighs. Other than modability, what is the benefit of these AL seats?
Chris Cervelli
Premier Motorsports
Chris Cervelli
Premier Motorsports
Why would you not just do this? (Check the Safer System Additions at the bottom of the page)
http://www.stockcarproducts.com/seats5.htm
I would rather trust myself in a Recaro composite seat than an alumium one with things tack onto it that have not been tested.
I am left to wonder then why the FIA only gives you 5 years on one if they are immune to aging or degradation?
Nice work John. I like the fact a brace will bolt to you added bracing instead of the back of the seat proper. Almost enticing.
At one time I was toying with the idea of building a composite seat. I'm thinking about it again. Perhaps once the car is done (with a FIA composite seat) I'll start working on molds. I'm mainly thinking about fit, containment, and lowering my height in the cockpit an especially the height of my legs under the steering wheel.
I actually think the Recaro Pro Racer is dangerous. Head containment but only shoulder support. Dumb. Just my opinion, mind you.
John,
When are you going to sell the pieces already cut so I can TIG them onto my seat?
Nice job!
Nice job!
