Looking for a lightweight battery
I was planning on mounting my Odyssey on its side, but when it arrived I noticed that it states "not for inverted operation" or something like that on it. Anyone have any problems from mounting it on its side?
The Odyssey PC680MJT that Skip uses appers to be about a 1 1/2 inch taller than a standard battery. It seems to me the only way to mount it in the stock location is flat with the poles facing forward.
FWIW I had an Odyssey PC680 in the garage for about a year before I installed it (been kinda busy...); it fired the car right up and seemed to have discharged very little while stored, unconnected.
The solution is to either to disconnect the battery if it is going to be stored for a long period of time or to use a trickle charger. A trickle charger for a normal lead acid battery can be used for an AGM battery though the ideal trickle charge voltage would be slightly higher so the battery won't be maintained at 100% charge.
Stephen
