BUMP STEER
Originally Posted by Bill L Seifert
Kurt, thanks for the input.
Geo,glad you chimed in, I kinda figured lowering the rack would be against IT rules. Besides going to 600 pound springs, I don't think I am going to lower the new car as much as I did the old 83. (The 83 was lowered 1 1/2 inches, I think I will just lower the new car 3/4 to 1 inch.) I know I have asked this before, but I can't remember what you told me. What size torsion bars do you have on your 944 race car?
Thanks everyone,
Bill
Thanks everyone,
Bill
Geo
I don't know about where you live, but I have owned my rains (Hoosier Dirt Stockers) for 3 years, and the only time they have been on the ground, was when I loaned them to a friend to take to Barber last year. I obviously don't worry too much about rain. (wait and see, I will use them next time out.)
What do you think about only lowering the car 3/4 to 1 inch, to help keep bump steer at bay?
Bill
Bill
Hehe. In Texas it either doesn't rain or we get an Act of God.
I haven't measured bump steer, but I'd imagine limiting the lowering would help in that regard. The real question is would you give up more in other places? I don't know the answer to that, but Jon Milledge recommends running at the legal minimum ride height. In fact, he says it's IMPORTANT to run at that height. I don't know why.
All I could recommend is to test it out. I think the rear will accomodate a 1" ride height change, so if you figure out how much to adjust toe when changing from one ride height to the other (or better yet, get toe plates), it would be interesting to know the trade-offs.
1 Post
No matter how 'beefy' I do not like the single shear bump steer systems. Attached is a photo of the system we use. Note that our spindle has been lowered by 30 mm hence the large adjustment that we have.
If I am not mistaken manufacturers design road cars with bump understeer - not IMO ideal for racing.
Regards
Johan Vermeulen
Regards
Johan Vermeulen
Basic Site Sponsor
Basic Site Sponsor
Sweet. I understand that just lowering the tie rod end would produce a lot of torque in a single shear setup. That is why I raised the rack and bent the tie rod ends down. That left me with a pretty strong setup, but not as nice as yours (but not as obvious either). From the type of spindle/rotor, I assume that this setup is on a 911/SC/Carrera.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
1 Post
Larry
The car is a 73 RSR replica. More pics here: http://www.almost.co.za/
The original chassis was a '72 which was stripped down to the absolute bare shell. Stripped, resprayed and the rebuild with the best equiptment we could afford. Big reds, Quiffe lsd, 10" inch and 13" Hoosiers, etc.
Our motor popped (flywheel came loose and cracked the block). Now busy building a 3.5 lt race motor. Weight 860 kg (wet) or 1900 lb.
Johan Vermeulen
Johan Vermeulen
Originally Posted by Flat Top
No matter how 'beefy' I do not like the single sheer bump steer systems. Attached is a photo of the system we use. Note that our spindle has been lowered by 30 mm hence the large adjustment that we have.
Regards
Johan Vermeulen
Regards
Johan Vermeulen
"spindle lowered by 30mm"? Do you mean the spindle was "raised" by 30mm (like RSR shocks have)? Either way, that's a pretty cool solution. Do you have a better picture of how the bottom support is mounted? I looked at your web site, but the suspension pic was too small.
Currently, I use the standard spindle height and rack spacers to reduce the bump steer, but I've considered moving to RSR shocks (with the raised spindle).
It looks like you have a good solution to the single sheer tie rod drop link.
Geo, I have a toe guage, so re-adjusting toe is no big deal. I do remember Millidge saying that, so I guess I will experiment with it.
Here's one thing. I run both 16" and 15" wheels, to change the gearing for different tracks. I set my ride height with 225-50-16 tires on 7x16 wheels. When I go a different track, and use 225-45-15's on 7x15's, my car is a little low on ride height. (I also squashed my exhaust pipe backing into my garage.) That could be a problem if I won, but seeing as I finished 6th at my last race, very few people protest 6th place. But if I ever get good,(Slim chance) I will have to watch that.
To Larry Herman,
You didn't do that bending of cast parts on your 2004 GT3 did you?
Bill
To Larry Herman,
Bill
Basic Site Sponsor
Basic Site Sponsor
To Larry Herman,
Bill
Bill
![nono](https://rennlist.com/forums/graemlins/nono.gif)
1 Post
sjanes
Sorry, I meant raised by 30 mm.
Larry,
Here is a picture showing how the support is attached to the shock.
Bear in mind that raising the spindle by 30 mm on my '72 911 brings the ball joint very close to the rim (16"). I think the factory originally moved the spindle 18 mm. The larger the rim size used the less of a problem, obviously. When moving the spindle you also change the roll centre height.
Because I raised mine so much it becomes problematic to use heat to bend the control arm - not only does it need to be bent downward but the ball joint receiving end has to be curved in the opposite direction so that the hole retains some of its original angle.
Larry,
FYI, bump steer theory and corrections are further explained in Fred Puhn's, "How to Make Your Car Handle" and Paul Van Valkenburg's "Race Car Engineering and Mechanics" (both published by HP Books), among others.
Sherwood
Sherwood
1 Post
BUMP, BUMP, BUMP STEER.
I have found that using a laser pointer, bolted to the hub as shown, that projects a laser dot onto a sheet a graph paper works best.
Of course all the appropriate precautions to ensure repeatability such as applying the brakes, locking the steering wheel, removing springs and anti roll bar and IMPORTANTLY ensuring that your graph paper and spirit level is horizontal, have been taken.
Innovative and different. For example you do not need to take any measurements at all. Just plot your graph as the dots moves through its arc of travel. Just make sure you cleary mark the stardard ride height and use that as your reference.
When pumping the trolley jack a clear line is shown by the laser which I position about 2 metres in front of the car. The arc instantly reveals itself.
Johan
Johan
