Shock Setup (from gsum thread)
Lifetime Rennlist Member
I set my double adjustable shocks as hard as I can for compression and as soft as I can for rebound. If you are too stiff on compression, the car will be harsh, tiring and will behave badly over bumps. I can run much stiffer at Mid Ohio than at Heartland (bumpy track). Still compression keeps the tire in contact with the pavement as you hit a bump.
On the drop off side of the bump, you need it as soft as possible to come back into contact. Soft rebound also allows much earlier application of throttle.
Some of the best things to do are:
Set shocks full soft (B/R) and drive the car.
Repeat for full stiff.
Back off full stiff compression until the car is comfortable and controlled over bumps.
Do the same with rebound.
Go to full soft and move one at a time to develop feel.
Keep doing things like this to get a feel and teach yourself that some stuff is not all that intuitive. If the car is hopping over a series of bumps, the rebound is probably too stiff, rather than the compression being too stiff. If you feel like you are waiting for the car to settle in esses, again, rebound is probably too stiff.
Learn to trust what you feel. Have someone make setup changes to your car without telling what they have changed. Do some laps and tell them what is different. Maybe they did not really make a change that time.
Get a copy of Carol Smiths 'Engineer in your pocket'. It is the best practicl tuning guide you will find.
Originally Posted by PatK-Mpls
Do you tend to adjust the front and rear together or make those determinations based on turn entry/exit needs from the car?
From there, I tune one end or the other as needed. My car is very stiff (wheel rate is about DOUBLE the corner weight) so it responds highly to shock changes.
The proper way to analyze shock setup (assuming you have a DAS) is a frequency and/or displacement analysis. I am not willing to go into that here as that analysis is well beyond a simple g-sum concept and too many people here seem to be having trouble with that. Furthermore, until you can consistently drive your car near the limit all the way around the track, detailed work on the car/setup is largely an unnecessary distraction.
Originally Posted by seege
Is Heartland still bumpy after the repaving they did?
First, you tell us we are all too stupid to understand your expertise. (BTW - Have YOU ever tuned the shocks on a car using DAS or is this another theory?)
Then you saywe are wasting our time if we can't drive at the limit. Since this is my thread, and Pat is the other primary participant, I take that as a statement that neither Pat nor myself are capable of driving at the limit like you are. Or is that just more theory too?
Of course, if you were really smart and really understood this stuff, you could explain it in a way that even us inbred idiots could understand.
Hope that helps!
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Mark, thanks for the knowledge given to those of us who can admit that we have much to learn.
Basic Site Sponsor
Basic Site Sponsor
Mark, I have found that too much rebound will tend to mimic bumpsteer in undulating corners. The steering is loading and then unloading because the wheel cannot return to the road fast enough. I would keep softening the rebound until the car can smoothly track over the undulations. Any thoughts on this?
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Still plays with cars.
For CC's benefit, having a better suspension set up on a Ferrari Challenge car took more than 2 seconds off a "best" lap time. Changes on the F car are limited by the rules, so it' spring packers and changes to the ride height (no aero tricks like Mark has). And yes, the driver is absolutely great.
Mark if I may, you set compression very hard and rebound soft to maintain contact. How is the ratio of compression to spring rate? I think you hinted at it, but I'm not sure I understand it. Rebound has to be firm enough to prevent oscillation. Are you using realtively soft springs and using the shocks to manage compression? Note the GT3 set up seems to do something similar. The shocks are way stiff and the spring rates are low. Rebound on the bilsteins is fairly stiff and I think there is room for improvement there .. or, my shocks are shot , which is possible after 12,000 odd track miles.
Mark; Save it, Bro. We already know how ignorant you are. Thanks!
Larry; If I may. You are probably feeling the impact-float-bam-float-bam of too much rebound keeping the wheels from returning into the valleys of bumps. I had not considered it, not having discrete adjust myself, but you are likely correct in your theory of steering subterfuge.
And so from this we learn that...
If your car handles like a bag a crap, or even if it is only off by a tad, and you are not Michael Schumacker, just shut up and drive. You have no business trying to make it better, and will probably make it worse. Do not attempt to lay down a baseline and then build a knowledge base - as dear Sunday has suggested - for understanding by probing the cause/effect workings of your suspension adjustments because you are not yet worthy of such success and enlightenment.
Or, could the reason for your not "reaching the limit" be that you CAN'T because you must remain ignorant and not touch anything? Or, are you reaching a "false limit" because your car is a pig?
Stunning. Simply stunning.
Distractions in the thread aside, this part interests me greatly! Is that consideration of very stiff - is your reference relevant only for sports racers and formulae cars, or would that by any chance carry over to our door-slammers?
The natural frequency of each corner depends on sprung mass, unsprung mass, and wheel ratio.
Formula I've used would be
=187.8*SQRT(wheel ratio/sprung weight)
Wheel ratio can be determined by spring rate and ratio how it affects wheel (leverage and angle)
Sprung weight is a bit more difficult. I had corner weight, then I weighed the wheel and the sprung mass of suspension arms, brakes and such by removing spring and putting it into ride height.
Ranges of frequencies commonly found in different types of vehicles are:
Very soft passenger car: 0.5 to 0.8 Hz (30 to 50 opm)
More sporting passenger car: 1.0 to 1.3 Hz (60 to 80 opm)
Modern sports car: 1.1 to 1.5 Hz (70 to 90 opm)
Pavement race car with modest downforce: 1.5 to 2.0 Hz (90 to 120 opm)
Modern race car with ample downforce and ground effect: 5.0 Hz (300 opm) or more
hrk
