Disabling PSM
Oh, just disconnect the wiring. There should be a plug in there somewhere?
Vaughan:
There is a wrap around black plastic module that looks like it contains the sensor. There is a wire wrapped around the outside. The problem is it is under the steering column and you can't see what the heck is going on and how to disconnect the wire.
It so happens that the ABS/PSM is off all the time now when I have the CAN bus connected so I am going to use it to defeat the PSM.
