All cars feel like crap at the limit!
#31
Originally Posted by PatK-Mpls
Larry - If your car feels 'lousy' at some or all of the portions of the turn during the limit (given your relative driving skill) I suspect your setup is off.
#32
IMHO, the car should feel beautiful at the limit... (of course this assumes that I have ever been at the "limit".... I do know I've been over it quite a few times).
The car should feel like it is gliding or floating...... almost like walking on ice... you can feel your feet slip a bit, but you are balanced and in no real danger of falling.... that is where the tires are at their maximum... you can almost feel the steering lighten up.... the car feels "up on its toes"
That's the perfecnt scenario....at that point more slip angle will simply make the tires scrub, and slow you down, and beat up the tires.
If the car is not set-up well... say the front gets there before the back....then you get understeer... if it is mild, then it is still faster to "straddle" that optimum point.. even if you are scrubbing the fronts a bit.... or use throttle steer to equal it out...
If it is really bad, then you just have to drive to the weakest end of the car, and get your *** kicked.
Since the car is almost never "perfectly" set up, you will be wrestling with it to some extent at the limit.... as the imbalance gets worse, the car feels more and more "crappy"
#33
Still plays with cars.
Larry - great topic. Here's my take. When at the limit the car is not stable because we are playing catch and release. Tires have their maximum grip just as they begin to slide .. any more and the grip goes away fast. Assuming we can balance the car right at the limit of the slip angle of the tires in the first place, (what I call The Limit for any given set up - admitting that The Limit can be different for different set-ups) minor irregularities in the track surface force us to make constant corrections as we exceed The Limit and then gather the car back up. It is hard to keep this up for very long. This leads to my conclusion, "does the car feel like crap, or are we just not comfortable with the car when it is skating on The Limit"? Put another way, does my car feel like crap or do "I" feel like crap???
Best,
Best,
#34
Originally Posted by Darren
I guess it depends on what you mean by "feel like crap". In my case I meant that the car goes from being very tame/neutral to being slightly scarey at the limit. I like the oversteer at that point, but its a bit unsettling when the back end steps out and you just hope you guessed the speed well enough that it doesnt keep coming around.
38D, I think its entirely possible if not widely probable that one can know that a car feels lousy and know change is needed yet not know how to execute that. There was a thread on here way back where I said I thought one of the big drawbacks to the HPDE system is to always try fix the driver and not the car ... it might make for a highly adjustable driver but not a very saavy one at effecting good setup changes to the car. And then in contrast, if the change doesn't give the driver confidence, it doesn't matter how much it empiracly "improves" the car since a large part of feel is mental anyway. At least that's my way of looking at it.
#35
#36
Best,
Best,
Nahhh
Very right though, how the driver feels is a major influence in the perception of speed.
#37
I read a quote a few weeks ago that struck me:
"I couldn’t have driven one single lap more. I wouldn’t have liked to drive a single meter (3 feet) more with myself at the wheel at that speed"
From Jan Magnussen after his record? run at the Nurburgring in a Z06.
To me, that means that to drive the car at the limit, on that track, scared the crap out of him. If the car was totally comfortable at the limit, I'm sure he wouldn't be scared. But to drive the car as fast as a test driver does (btw, are these guys crazy or what???) I don't think it ever feels "under control"
![](http://members.roadfly.com/woodm3/ring.jpg)
#38
Basic Site Sponsor
Basic Site Sponsor
Many of you have mentioned setup. I think that my GT3 feels wonderfully balanced, and reacts predictably up to and even a little over the limit. It is just that the beautiful hooked up, "do anything I want it to do" feel that it has at 9/10ths morphs into a car that does not want to turn it, then wants to over-rotate, and then demands that you keep your foot in it, and countersteer in order to keep the back hooked up when you are at 10/10ths. I still submit to you that it is because you are at the limit of the tires, which defines the limit of the car.
With street tires, that edge of their grip is so wide that you can slide the heck out of your car, and really play around with the best slip angles comfortably. And the car feels like crap... The problem is that when you get to stiffer suspensions, and grippier tires, your edge gets really small, and the car get really tight and uncommunicative, and most people will not or cannot get those tires right on the edge consistently. And so they will drive them around below their limit, and think that everything feels fine. But if they are not sliding them, and they don't feel loose, then they are not at the limit.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#39
Other times, the car is perfect, but the driver has the yips, and this is even worse - it's like I have no confidence in the car even though it's handling beatifully, so I cause it to do really weird things (you can't tiptoe around - the car needs to know who is in charge).
And then there are the days where it all comes together, and the car feels beautiful at the limit. It's that drift thing vs. that sliding thing. These are the days I live for.
So Larry, I agree, in general the car feels like crap at the limit, because we seldom get it perfect. But when we do,
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Cheers,
Bruce
PS - the Big Belly Racing motto is STFUAD, a phrase our crew chief has been heard to utter once or twice, in general when one of us complains about the car during a race. Stands for Shut the F*** Up and Drive
#40
Larry, I guess we were posting at the same time. In your last post, you mention the behaviour of the car as you are just crossing the limit, and I think we're in violent agreement on this point.
For a particular track on a particular day, you can get a great setup that works pretty much everywhere on the track, and will react predictably in the spots where it is not ideal. But, when you put in a lap that is right on the edge, while the setup will help, every flaw and variation in the track will cause the car to dance a different way. When you are dancing right on the knife edge, the car really does feel like crap becase it's really hard to anticipate exactly what's coming next and there is a lot of reacting going on. It's why we can't run qualifying times lap after lap in a race - most of us can't keep the focus required to continually catch and adjust (Bob - I thought catch and release was a game we didn't tell our wives about ...) the car for more than one or two laps.
Cheers,
Bruce
Cheers,
Bruce
#41
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by brucegre
when you put in a lap that is right on the edge, while the setup will help, every flaw and variation in the track will cause the car to dance a different way. When you are dancing right on the knife edge, the car really does feel like crap becase it's really hard to anticipate exactly what's coming next and there is a lot of reacting going on. It's why we can't run qualifying times lap after lap in a race.
#43
Here's a gratuitous photo essay on the subject:
This weekend, I spent a lot of time on just this side of the limit. It felt great.
![](https://forums.pelicanparts.com/uploads6/Almost+Two+M1126055212.jpg)
![](https://forums.pelicanparts.com/uploads6/Up+and+Downforce+M1126055249.jpg)
But then I had a front pair of brake pads go down to the metal, and I spent a little time on that side of the limit, which didn't feel so great.
![](https://forums.pelicanparts.com/uploads6/Last+Moment+M1126054513.jpg)
![](https://forums.pelicanparts.com/uploads6/Off+Road+M1126054567.jpg)
Although I admit I felt better when the car stopped on just this side of the corner station.
![](https://forums.pelicanparts.com/uploads6/Perfect+Stop+M1126054592.jpg)
![](https://forums.pelicanparts.com/uploads6/Smile+M1126054608.jpg)
'Happiness is not hitting concrete.'
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
#45
Some thoughts:
1) HPDE really isn't intended to teach people to drive at "the limit"... IMHO either teach yourself, or go to racing school
2) First, you have to learn to drive the car to the limit as is.... then you can work on improving set-up... most of us have had suspensions break, tires lose air, etc during a race and have to adjust... so it is still up to the driver to use what the car has at that time.
3) Driving style greatly affects how a car responds.. two guys walk a tightrope...one guy goes across like a morning walk... the other falls off.... same tightrope... if I go in a bit too fast, or over-rotate the car, I will be struggling with the car the rest of the way through the turn.
4) For a given car and turn the "limit" is a sweet spot where the tires are at optimum slip angle... real world we are balancing steering, throttle, (and even brakes) holding the car in a band around that sweetspot... IMHO, the guy who can stay closest to that sweetspot witth the fewest adjustments to the car will be the better driver.
5) Ideally, the front and rear tires will be in that sweetspot at the same time... to the extent that the speed at which they find that sweetspot differs, then the car oversteers/understeers and the driver has to wrestle more and more with the car to keep it balanced
