Miata Dedicated DE Car
#46
Originally Posted by Wreck Me Otter
Not to worry Drew, after a few races, you'll be replacing those too... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#47
Originally Posted by ColorChange
I am talking strictly DE.
Colin, RXdoxc and others:
That is precisely my biggest concern DE'ing a low powered car, getting slowed down in the turns by cars I can't pass. That would be no fun. Did it happen a lot?
Drew:
How often do you get your cornering ruined by a point and squirter?
Drew:
I said I wouldn't get into the Porsche vs SM debate, but I'll dip my foot in the pool: If I was only going to DE the car, I'd rather run a Porsche, aka turnkey track car. However, if my local track was very technical with minimal straights or I had concerns about safety due to lack of runoff areas, I'd lean towards a SM. Just my $0.000002.
#48
Lather, rinse, repeat. It got old.
That being said, driving such a slow car taught me what I know today (club race rookie this year, 3 races, 3 podiums).
#49
Originally Posted by gbaker
Greg,
You can get this whole package at Robinson Motorsports. Mick Robinson was my SCCA instructor and he has a well-respected operation with some excellent people.
I know it's not close, but I suspect you wouldn't mind escaping those winters for some occasional Florida sunshine.
Tell him I sent ya.
Tell him I sent ya.
Thanks. His was a name that came up when I talked to another shop. That shops advice was to have the car at a shop central to where you would be racing. I think I could handle Florida in the middle of the winter.
#51
About Nascar,
I thought you wanted to slow down. These are very fast.
Lots of steel around you, not much tire for 3500# weight.
Not cheap to run since weight eats tires and brakes.
#52
NASCAR car would be awesome and you could put a relatively sedate motor in the car~ 350-400hp and be reliable. Brakes might be a concern but $$ could solve that problem. Not sure what tire availability or durability would be.
Friend drove an older WC car at Road Atlanta and said it was one of the most fun things he had done. This is a guy that has driven 996GT3RS's, etc. He said the acceleration was unreal.
#53
SM is the best.
I agree that you will have trouble in DE with point and shoot types. What actaully helps is bunch of race decals. Then some folks get the message that this car is fast. No decals and it will look like and old slow miata.
Also of you can run with group that allows open passing then you can just pass them in the corners and be done with it.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
STILL... you will learn an awfull lot trying to hustle a low hp car around the track and how to pass those big hp point and shoot types.
#54
Hmm.... one for, one against.
What do you think about the NASCAR car idea?
Boy, you're a guy of extreems aren't ya. Miata or NA$YCAR Cup car. Why not try something like a 964 cup car:
-factory built with all the safety stuff
-fast enough not to get bored
-already developed
-already has a class to race in when the kids grow up
I don't know how cheap one of these would be to run, but others here do.
#55
sjanes, I know I sound schizoid, but here is what I'm thinking.
Guys regularly put these things into walls and each other at over 200mph. Almost always they walk away no matter how ugly. I think they are the safest cars on the planet. Now if I have it geared to go no faster than 140, I figure I should be in pretty good shape. I get to go fast, safely, and they are supposed to be great fun. The drawbacks are higher consumables, more maintenance cost, and probably more set-up work. Also tailoring is a little more difficult due to the weight. I would drop the strain on the motor (lower the hp) to increase reliability. Seems like a possible alternative.
Check this out. http://www.cars-on-line.com/21046.html
The other is the new '06 Pro spec miata. They are supposed to have these for next season and I would try to get one. The biggest concern here is getting stuck behind other cars. It may take some more set-up work and not as be safe as the cup.
964 means old and higher chances for major mechanical problems. I really don’t want an old car.
#56
For what its worth, I've got an '01 996 thats fully prepped to just beyond PCA stock class standards (interior is stripped since its prepped for Grand-Am CUP racing) and upgraded to a 2005 spec 3.6L engine and ECU. I'm likely going to upgrade to a 997 for next season and will probably be selling this car in a couple of months once the season is over. Stock engined 996 with trick suspension and all the safety equipment you could ever want might be something to consider. It's also already got AIM data acq. installed. And its fast enough at DE's that you have no problem getting point by's but isn't so fast that you're worried about doing any real damage to yourself in a wreck of any kind. There are also a few other similarly prepped 3.4L cars out there for sale currently as well.
Brian Bailey
Autometrics Motorsports Porsche 996 - Grand-Am Cup #45
'87 Porsche 944 Turbo - PCA GT3s
#57
Hmmm, interesting idea, but: "As close to the real thing as possible" might or might not mean "safe as Buddy Baker's car" IMO. Also, I'd bet that a 5 year old Nascar or clone won't be fundamentally less problematic than any other older race car...
The miata will probably make you happiest, for a while, and then you can move to something else. In the mean time you'll be driving. Safely.
#58
Super Moderator
Needs More Cowbell
Needs More Cowbell
CC,
If you are looking at NASCAR type stock cars, a road racing chassis with the Jericho transmission is suggested; the standard speedway gearboxes are not well suited to road courses.
#59
Super Moderator
Needs More Cowbell
Needs More Cowbell
#60
Originally Posted by Greg Fishman
Greg,
Thanks. His was a name that came up when I talked to another shop. That shops advice was to have the car at a shop central to where you would be racing. I think I could handle Florida in the middle of the winter.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
