Cool Shirt washing?
Addict Rennlist
Jim
Turn the shirt inside out. Hand wash in cold water with Woolite. DO NOT WRING OUT. Lay flat to dry. Be very very careful with it while washing.
I hope that advice helps.
cheers
Dave Parker
Manager, OG Racing
cheers
Dave Parker
Manager, OG Racing
OG Racing
Your Source For Motorsports Equipment
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Sparco's Largest Distributor for 28 Years
PFC Distributor for 27 Years
Pagid, Alpinestars, MOMO, OMP, Hawk, Bell, Aim, G-Force, HJC,
HANS, Arai, Simpson, Brey Krause, Longacre, CoolShirt!
Supplying Track Junkies for 34 Years.
PCA Club Racing - National Sponsor Since 1998
A Veteran Owned Business
Check out our blog!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Check out our blog!
Thanks guys.
I've used mine with/without a T-shirt and my Carbon X gear. Both on top and underneath. Guess you have to decide how cool you want to be.
Originally Posted by jrgordonsenior
I used mine for the first time recently and after wearing it for 2 days I was wondering....Does anyone wear a t-shirt under the cool shirt?
I have had my FAST cool Shirt over 3 years, I was told to turn it in side out, use the net bag that came with it and wash on gentle cycle with ALL clear. Living in South Fla. It really works. I use a "wicking" t-shirt And it gets so cool that I cycle it on and off except in the pits. FAST makes a great product.
I'm in....
Don't neglect the inside or you may have a nice layer of black slime in the spring. I run diluted isopropyl alcohol through the hoses. You can just connect the shirt, run the pump and fill it with some and then drain as much as you can out. I made a spray bottle with connectors so that I can clean out lines and shirts separately.
I usually dump some bleach in the cooler with some water and run that thru the shirt before washing or storing. The sludge that ends up in the tubes will slow down the water flow if you don't keep after it. Otherwise just toss it in the washer inside out on the delicate cycle and hang dry.
We wash and dry ours inside a pillow case using Molecule Wash detergent. I seem to recall reading somewhere that putting it in a pillow case is easier on the tubing. But who knows?
WRONGLY ACCUSED!
Received 4,326 Likes
Garment bag with molecule. I have probably washed it 50+ times and it is still in good condition.
