Track Day Data Sheet
Old 04-21-2005, 04:37 PM
ColorChange
ColorChange's Avatar
Default Track Day Data Sheet
Here is a data sheet I wrote for logging all the info. Please tell me what I am missing or any other suggestions you have.
Data log sheet
TIA
Old 04-21-2005, 04:42 PM
APKhaos
APKhaos's Avatar
Tim,
Looking for a crew chief job? There a position open in my team for a guy with your approach.
Nice work!
Old 04-21-2005, 04:59 PM
Greg A
Greg A's Avatar
Very thorough sheet. Here are a couple of items I didn't see on the sheet that you might want to consider:
Wind level (a very windy day would obviously effect your lap times and it's good to note that b/c it might not be obvious when you review the video at a later date)
Mileage in/out
engine hours of operation
Hope this helps!
Greg A
Old 04-21-2005, 05:29 PM
ColorChange
Tony: You're assuming I will know what to do with all the data.
Greg, added the wind, thanks. I can get time and mileage off of my data system.
Old 04-21-2005, 05:31 PM
Jarez Mifkin
Jarez Mifkin's Avatar
You might want to add your cold air pressures from whenever you get to the track
Then right before your first session (cold)
then right after your first session (hot)
a space for how much they went up
Then a space for what you adjusted them to (hot)
Then start all over for your next session with your adjusted pressures and see what they've dropped to
Old 04-21-2005, 05:48 PM
ColorChange
JM: Thanks, changes made.
Old 04-21-2005, 06:51 PM
RJay
RJay's Avatar
I think you missing one big variable that I can think of off-hand. Stabilizer bar position. Assuming of course that you have adjustable bars.
Old 04-21-2005, 07:06 PM
ColorChange
Rjay: If you look in the middle, you see sway bar settings. If you are talking brake bias ... me don't have.
I am going to add rear wing and gurney flap settings.
Old 04-21-2005, 07:31 PM
RJay
RJay's Avatar
Yep, sorry, missed the center text.
Old 04-22-2005, 09:53 AM
Nordschleife
Nordschleife's Avatar
you might like to record the driver weight - we saw a consistent difference in set up with SO and WH, where both are typically small but one was actually supersmall.
As well as the roll bar adjustments, check the wing setting.
I assume you don't adjust corner weights and suspension set up (apart from the shocks) on the day.
R+C
Old 04-22-2005, 11:25 AM
joey bagadonuts
joey bagadonuts's Avatar
Here's how I track tire info. In general, I'm usually rushing when checking temps so I need things laid out in a logical manner. Simply put, I set up the sheet so that it corresponds to the order in which I collect data:
Tire Order: LR, LF, RR, RF
Readings: Inside, Middle, Outside
I start with the tires which will lose the most heat and proceed accordingly. Also, I always take temp readings from the inside/out and write it down in the same order to limit confusion.
Old 04-25-2005, 10:55 AM
Fastest928
Fastest928's Avatar
One key data point)s) are a log of changes that are made session to session ...starting simple: fuel load as an example, to more complex changes: shock settings, bar changes, etc.
And always note the effects. Effects can be noted by lap times, segment times, corner or straight speeds, feel, etc.
Old 04-25-2005, 12:25 PM
ColorChange
I have modified the data sheet to make it more generic as people have asked to use it. Go ahead.
I have three temp conditions for the tires, Hot, AC (after coold down lap), and BC (big cool down lap). I usually have to take the car out of the track and drive around the street to further cool the brakes before pitting.
Old 04-25-2005, 04:01 PM
jrotsaert
jrotsaert's Avatar
Can you repost your current sheet with all comments?
THX
JM
Old 04-25-2005, 04:22 PM
ColorChange
Marc, I put these in a log book and you can see what we are doing to the car historically.
JM, just download it again from the original link. The more generic version is there and ask me any specific questions you might have.
Your welcome.
Quick Reply: Track Day Data Sheet
