Is $250 for painting DAS bar an OK price.
Old 04-20-2005, 05:57 PM
Sanjeevan
Sanjeevan's Avatar
Default Is $250 for painting DAS bar an OK price.
I only have a few days to get the bar, seats etc. installed, and don't have the time for powder coating, the bodyshop affliated to the mechanic quoted $250 for sanding/primer and painting. I had read here that someone paid $200 for powder coating, which he says may cost around $500. Is $250 an OK price for painting (I am not looking for a bargain here, if it is average I might go ahead with it, I would have said OK for it, if not for me reading here that powder coating was even cheaper). Thanks
Jeeva
Old 04-20-2005, 06:07 PM
RJay
RJay's Avatar
Jeeva
Offhand it seems a little high to me. I had my whole cage and interior painted for under $700 and these guys came to my wrenches shop to do it. We did most of the prep masking, etc...they did no sanding, but they did to a wipedown and surface prep. Primer + three coats. What kind of paint are you specifying? Is it a custom color?
Old 04-20-2005, 06:09 PM
Sanjeevan
Sanjeevan's Avatar
No, just any black paint, as you may be aware the DAS come bare metal.
Old 04-20-2005, 06:24 PM
Sam Lin
Sam Lin's Avatar
I'd just spraycan black it, after the event remove it and have it powdercoated. Last roll bar I saw powdercoated cost $275, and that's for powder which is far more involved to do and a much more durable choice.
Sam
Old 04-20-2005, 06:25 PM
Tom W
Tom W's Avatar
I paid about $200 to have my DAS bar prepped and powder coated. Given the difference in labor to prime and paint, $250 doesn't sound too bad (buy DIY would certainly be cheaper).
A semi-gloss black looks best IMO.
Old 04-20-2005, 06:31 PM
Sanjeevan
Sanjeevan's Avatar
Well I am getting the installation etc. done at the mechanic, so there will be extra cost involved in removing the bar/seats etc, but I may talk him about it (by the way this is not my long term mechanic , just had by brake fluids replaced there once).......Just now I called a different place, they quoted me $350 for painting, I said that is too much and the guy goes I can do it for 200...I paused and he says how much do you want to pay? as he can do anything but "you get what you pay for" ...and a cheaper job will just look crappy...so, now a "good" painting job is $350. AAAARGGGGHHH!
Old 04-20-2005, 06:36 PM
Greg Fishman
Greg Fishman's Avatar
Sam
My thoughts exactly. Or just primer it in flat black
Old 04-20-2005, 06:43 PM
mm86911
mm86911's Avatar
Save the expense and use a spray can. Most of the areas immediately visible should be covered in padding anyway.
Old 04-20-2005, 06:52 PM
mdbickell
mdbickell's Avatar
MM86911 is spot on. I painted mine w/ a couple coats of primer then a couple coats of krylon matte black. Don't laugh... it sound ghetto, but came out nice. It looks just as good as anything I've seen w/ the exception of the powdercoated cages / bars.
If you don't like the look, then you can have a shop do it and you're only out an incremental $20 for paint in the DIY scenario.
Old 04-20-2005, 07:02 PM
Sanjeevan
Sanjeevan's Avatar
Thanks a lot guy's, I am going to make it my wknd. project...I'll consider the powder coating later.
Old 04-20-2005, 08:35 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,691 Likes on 2,339 Posts
way too high. in price inflated california, i paid 150 for powder coating my roll bar. the job was superb.
Old 04-20-2005, 08:41 PM
38D
38D's Avatar
I probably spent $150+ doing it myself (by the time you buy the primer, paint, clearcoat, plastic to put up, etc.). It was a full cage, so it took more paint than just a bar would.
Old 04-20-2005, 09:23 PM
Patrick
Member - times 3
Patrick's Avatar
Find a local powder coating "job shop". I got mine done for $100. And put it in yourself!
Old 04-20-2005, 09:29 PM
Mike K.
Mike K.'s Avatar
Default I paid $340 US to have it powder coated black
in Orlando, Florida. I thought that was high but the mechanic said that was normal price.
Old 04-20-2005, 09:43 PM
Sanjeevan
Sanjeevan's Avatar
But....isn't powder coating more expensive than painting, my mechanic said it'll be atleast twice as much.
Quick Reply: Is $250 for painting DAS bar an OK price.
