Shave RA1s for 3200lb 951 DE use?
Originally Posted by a4944
Hi All,
I'm about to buy a set of 245/45-R16 Toyo RA1s for the next DE season. I've done a search and there are varying opinions on shaving for DEs. This is my first set of R compounds. I want them to be faster than street and have good wear. Car and driver weighs 3200 lbs. I'll be running the SE tracks (VIR, Roebling, Rockingham, CMP). Anyone with a similiar setup have opinions on shaving for DE use? Wear is my primary concern. Some of these tracks are hard on tires so I'm thinking full tread may be best.
Thanks,
Mark
Thanks,
Mark
Also, I have never heard anyone credible saying the RA1s need to be heat cycled before use. I have heard from App Tire, Vilven and various sources it doesn't require a heat cycle (unlike most all other R-compound tires). We started several races on sticker shaved Toyos and they wore just fine (I want to say we ran a 19 race season on 8 tires - 4 races at RRR that year and half those races were 1.5 hour or more).
I posed a similar question about heat cycling the RA1 on the Spec Miata message board last year. This is the reposne I got from a guy that works at the Tire Rack:
Mark -
Most R-compound tires benefit from heat cycling first, and you can't HURT a tire by doing it. The first time a competition tire is used is the most important. During that run, its tread compound is stretched, some of the weaker bonds between the rubber molecules will be broken (which generates some of the heat). If the tires are initially run too hard or too long, some of the stronger bonds will also be broken which will reduces the tire's grip and wear qualities. Running new tires through an easy heat cycle first, and allowing them to relax allows the rubber bonds to relink in a more uniform manner than they were originally manufactured. It actually makes them more consistent in strength and more resistant to loosing their strength the next time they are used. An important heat cycling step is that after being brought up to temperature, the tires require a minimum of 24 to 48 hours to relax and reform the bonds between their rubber molecules.
Representing The Tire Rack
877-522-8473 ext 643
damon@tirerack.com
MarkP
posted 07-13-2004 09:50 AM
Thanks!
Damon, can a first heat cycle be achieved while driving on the street? Say 5 miles of rural twisty roads at 40 mph?
Redmond, WA
damon@tirerack.com
Moderator
Yep. Just make sure to let the tire cure the full 24-48 hours before driving on it again after warming it.
damon@tirerack.com
Mark -
damon@tirerack.com
MarkP
Thanks!
Redmond, WA
damon@tirerack.com
Moderator
damon@tirerack.com
Mark, not to dog you or anything, but Tire Rack doesn't sell Toyo's (nor do they plan to in the future according to one of their sales people) So I wouldn't listen to them to much when it comes to Toyo's.
Hey all;
Heat cycling tires is a proven technique for increasing their longevity and consistency, and it is not a point you can argue. I think it may effect Toyos less because they are not a full bore soft compound race tire, but more of a compromise tire with a tougher compound that breaks down less and so does not reform as much either.
Unless you drive really hard, particlularly on a poor suspension setup, you will not need to shave them. People who race generally do shave because they are pretty squirmy at full tread, and they also will overheat under the cap ply under severe racing conditions. For a first time R tire DE-er, I think you'll be fine at full tread.
Instead of shaving them, do them a favor and get some negative camber in your alignment settings before you use them. If you have none, this will kill them faster than shaving or not shaving.
Thanks all. Went with shaved at 5/32, it was only a few dollars more per tire at App Tire. I'm running -2.2 neg camber so should be OK there. Looking forward to running them in February at VIR.
Mark
Mark
Mark,
Are you going to VIR w/ NASA? If so look for me in the black RSA.
I just went to shaved toyo's from full treads. My full treads lasted forever. They would still be on the car if it wasn't for all of the nails lying around Summit Point.
Jim
Jim
No, going with THSCC for VIR full. I will be running some NASA events this year though. Did the VIR North one last year and had a great time with the passing rules.
Mark
Mark
Mark, are you doing the Time Trial as well? That THSCC event should be fun. From my recollection, the passing rules for THSCC were the same (passing anywhere w/ a point by for solo and instructor groups) as w/ NASA. That might have changed in the last year however.
Yes on the Time Trial. I run advanced group with THSCC and they only let you pass on the certain straights with a point by. I've been running with them for a couple of years now (advanced for a year). It may be different for the instructor group. I'm doing time trial just for fun. I'm in the SPO class because of the Autothority Stage II chip which increases boost. Radicals are in the SPO class. I'm not really competitive with many of the cars which run in that class. The new rubber should help some though.
Mark
Mark
Originally Posted by 930man
are RA1s substantially better than Kumo V700s vir eats my front drivers side in 8 days at VIR all the rest hold up ok. sounds like i should try the RA1s
cool thanks rjay i bought alot of tires last year with the 944 turbo s .. would like to try something different this year
Mark
Mark
If I get up there, I'll try stop by and say hello. Otherwise, don't worry too much about the Radical, just try put in some good laps (and beat the M3s!).
Take care and have fun!
