DAS semi-Advanced Analysis Help
Lifetime Rennlist Member
Originally Posted by carreracup21
The thing about data analysis, and why I have a hard time seeing the utility at my lowly level, is that it seems to be a circular type of problem. I mean the data might tell you that the car can go faster, but unless you have the actual driving skill to balance the car properly and make it go faster, it doesn't really matter much. We all know that putting the car on the edge all the way through the corner and maximizing exit speed is the goal. Doing that takes experience and practice so you can feel the grip that is there and use it. Looking at the graph, it seems to me that you did not carry enough speed into the corner and the g-sum fell off, but as the radius tightened it came back up. Once back on the gas, all that hp is tough to modulate and the rear got loose dropping the g-sum and costing exit speed. I think it takes a lot of skill to go barreling into a corner so fast that the car will barely turn in, but that's what you have to do to keep everything maxed out. Then you have to carefully manage that insane entry speed with balanced inputs as the car wants to swap ends to mid corner and beyond. Like I said, looking at a mathematical representation of what's happening after the fact doesn't show you how to do it, just that it can be done better and we already know that so what's the point. I do think it is fun to think about driving though and if it helps you remember what was happening so you can relive it .. then that's probably not a bad thing.
TIRE GRIP CHANGES WITH LOAD. A tire may be able to give 1.1 g's with it's static share of the car weight, but if you add another 50% to that load, it can only pull .8 g's (that is an example). That is the nature of tires. That is what makes driving at the limit so challenging. One tire (or more than one) is always losing grip. That does not mean you are going as fast as you can. You, as the driver, can manage the weight and still get more out of the car.
Lap time is what ultimately matters in terms of going faster. How does one driver's times stack up to others? In the DE environment, that is tough as there is probably not another car that is the same. BUT, you can go look at lap records for certain classes to establish a target. Spec Miata is a low HP car on DOT tires and the drivers tend to be very good. T1 is another calss to compare to - better as the cars are more powerful but the fields are smaller so it is not clear that the lap record for T1 is real. That is an excercise that Tim (or anyone else) can go through.
I think at my experience level, precise analysis of the numbers on a particular corner is pretty useless. My plan of use is is two-fold. First, add video. Use the maps and data to identify fast and slow laps, identify where I was faster, where I was slower and then use the video to help identify what I was doing right/wrong. Second, convince everybody I know to buy a system so we can overlay our data and compare notes. My intent is to use the tools at a very high level, not trying to examine each scrap of data,which I suspect is too myopic. My attention span is sufficiently short that I have littel hope of analysing G-Sum data for each corner. I admire CCs determination, but I for one, can't emulate it. OTOH, If I can reasonably relate the numbers back at a high level to what I was doing when I generated them, then, for me, it will have been money well spent.
I was thinking it would be cool if you had a DAS that could talk to you through a headset during the run, like a coach. It might say something like "go faster you idiot" , or maybe for the more analytical, "brake now, 2.5 mph slow mid corner, accelerate" , or even "g-sum is dangerously low, go faster now please". Hey someone will probably patent that idea...oh, well. Another thing the DAS can do is give you a "best possible" time where it looks at different segments of the track and figures your best speed for each section during a run of several laps, then gives you a cumulative best time. Then you can shoot for that great time because you know it's possible, if you can put it all together for the perfect lap.
Larry, I agree and that is why I rode with Fishman and am hoping to ride with and get Norm's data.
Actually Carrera, on this turn, I handled the entry pretty well. This is normally the hardest part of the turn but on this particular lap, I did it fairly well.
A. For the first second and a half of the turn, I transition from threshold braking to full lateral g’s while maintaining a g-sum of around 1.2 You can see the cursor is at a point where I am pulling -0.8 long g’s and -1.0 lat g’s. That's real nice trail braking.
B. At point B, I overbraked/under accelerated just a little bit or didn’t tighten my line enough and this is what dropped my g-sum to 1.0 for about a second.
C. By C (about 2 seconds) I am back to pretty good and maintaining a high g-sum using the throttle while lat g’s stay about -1.1g.
After that, I got into the previously discussed oversteer trouble.
Mark:
I use corner radius to partially look at the line I chose. A detailed response would take a while. I am not real concerned about steering smoothness unless it affects g-sum (and I don’t have steering input yet on this car). As far as I am concerned, you can saw the wheel like a banshee as long as your g-sum is high.
I agree with comparing hot lap data. I just need to find someone who is comfortable in a similar car. Norm, are you listening?
I disagree about your conclusion on the data saying I need to be thinking throttle. The data shows the exact opposite. On this turn I blew the exit, precisely because I was trying to squeeze too much throttle too early and snapped ‘em loose.
Guys, street tires have less variation the r-rubber. My data shows how consistent a lat g max of 1.1-1.2 and a g-sum of max 1.3-1.4. Yes elevation and camber change this but the data is wholly usable.
Mark:
BWAHAHAHAHAHAHAHAHAHAHAHA!!!!!
Thank you, that was great.
A Banned 'Haiku Victim'
Location: los angeles, san francisco, phoenix, tokyo, taipei
Originally Posted by Premier Motorsp
What a pathetic little life you must lead.
CC, It's interesting how well the Lat. g (yellow line) and the speed (green line) inversely correlate. They almost look like the same curve. One thing that I noticed when I was getting faster was how you can use lat G's to slow you down rather than brakes in some corners. You will feel to fast on entry, but by balancing the car and turning in a little earlier, you can scrub the speed with g's and stay at peak g longer at entry. It's hard for me to see, just where you released the brakes here, but it looks like you may have taken braking too far into the corner and it resulted in lower g sum at point B after you had it nicely maxed at point A. The graph also shows just how spinning the wheels can ruin your exit speed. It looks like the green line lost 3 mph on exit and dropped the whole green exit speed curve to a lower level. That is where the time is lost down the whole next straight and is a bigger mistake than the drop at point B as far as lap time goes.
I have looked at the PCA race results and will compare them again after I put my Hoosier's on (after I wear out my RA-1s, which could take a while).
Jim
Jim, I think C. Price did a 2:12 at VIR in a D class 964 C2 ( re-classified to RSA) at 2760 lbs. in the last PCA race. Full race set-up with JRZ's, Hoosiers. A E class 964 driven by someone like Savenor ( or maybe Ghetto ) could probably do 2:12 -2:13's also. The VIR times are actually nearly exactly the same as WG with maybe a tenth or 2 difference believe it or not.
Someone I respect a lot who drives a 964 Euro Cup and used to race D class, now GTC1 told me " the only thing I ever did to my car that made a difference was tires". I tend to believe it that, but a good set-up and alignment is also critical to getting good handling. I use the non-adjustable bilstein cup shocks/springs and they are fine. I've got sway bars that I can adjust for balance. I think 2:17's might be a good number to shoot for with the RA-1's. Hoosiers will be 3 seconds or so quicker.
LOL, thanks for jumping back in, Haiku target.
Though I may not quite agree with how he states it, I'm all with Henriksen. To put it in terms that are of interest to Tim, I think there's a well-established relationship between steering wheel input and long. accel. Hey, the less you steer, the faster you go. The mu-slip characteristics of tires are easily understood, if not so easily quantified. Gaining the intuitive understanding of how to best employ them while behind the wheel is what Tim and indeed all of us continually strive to improve.
I'd be most interested to see comparison between lat g, yaw rate, steering wheel input, vehicle speed, and corner radius calculated from the above (from lat accel, steering input, and the other sources). Once you can compare those, you really get an idea of what the driver's doing with the car vs. what the car's capable of... but applying that in the real world is still tough due to elevation and loading changes. I do have data with all of the above excluding steering wheel angle, unfortunately. Watching the yaw rate stability gives a half-decent idea of how well the driver's driving, in the absence of steering angle, but the primary focus is still smoothness, there still completely lacks any ability to compare with the "idea" or "best" line.
Which brings us full circle back to step 1, how do you even use the data to determine a "Best" line? and we're still back to the #1 criteria, minimum sector time. Back to the old (proverbial) stopwatch. Though I will agree the DAS system gives me a far better opportunity to compare the minutia of my driving, it's still up to me to turn the good lap times...
Chris, if you'd like to explain to me why it's rational to maximize gsum at the expense of laptimes, I'm all ears. From where I'm sitting, the emperor has no clothes. LOL is an overused acronym - that 'saw the wheel like a banshee' had me busting out laughing at my keyboard. I actually wasn't being snarky, I appreciated the belly laugh!
Edit: Oh, and thanks, Ghetto
