Left foot braking
LFB is a tool in the toolbox. Some cars pedal layout and foot box require it.
Is it a must? Given that fact that well-practiced and near perfectly executed conventional RFBers routinely beat less perfect LFBers every day, it really boils down to “how well do you execute?”rather than the technique itself.
A great deal of LFBers begin with that technique in karts, some transitioning from auto transmission street cars to track cars do so as well.
Given that the brake pedal is the BEST and most effective tool for governing and adjusting weight distribution on the only four connections with Mother Earth, the tire contact patches, LFB can offer a more sensitive and nuanced rate of transfer of that weight distribution.
Can it make you quicker? Only if you are doing executing the entire procedure at least as well or more likely, BETTER than you RFB.
If you’re interested, I recommend practicing very assiduously all the braking exercises you did to hone your current braking technique, AFTER practicing extensively on the street to develop the feel for pressure and more importantly, eliminating as much as possible the inevitable overlap between throttle and brake application, which is common in the beginning.
But then, on the track, start with areas that require little slowing, as opposed to a lot. This is the most common use for LFB I see on track. Threshold or heavy braking (getting rid of more than 25-30 mph or so) stays with the dominant, trained and practiced foot. For places like Turn 5 and Turn 16 at Sebring, you begin there using LFB.
Again, while there are statistical and topically beneficial differences in the speed and distance covered between throttle and brake applications using LFB, the practical benefit is limited to how well the car responds when the choreography of the pedals is correct.
That choreography, and the car, doesn’t know the difference between LFB and RFB, in my experience.
I started using LFB in my old 944 Turbo. It had a lot of turbo lag, so lifting off the accelerator pedal was the last thing I wanted to do for decent lap times.. So, anytime I needed to brake but not downshift I would LFB.
It took a while to develop dexterity in my left foot as its only prior role was clutch action. I did some seated exercises (e.g. rolling a basketball around with my left foot) and forced myself to use LFB when driving an auto trans on the street.
Now, I brake on the street exclusively with my left foot (when driving my auto cars). In the SPB I only use it when I need to set the nose or scrub a bit of speed without downshifting.
As others have said, it's a good tool to have for the times when it would be useful.
The following 2 users liked this post by Jas0nn:
LuigiVampa (01-12-2024),
ProCoach (01-11-2024)
Basic Site Sponsor
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
Another necessary tool.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
When left foot braking, one thing to watch out for is what I call "phantom clutching".
I left foot brake all the time in my formula car, as these Hewland gearboxes shift fine without using a clutch. However, we sometimes find small brake pressure spikes in the data when I am upshifting. It seems that I am so used to manual shifting in street gearboxes that my left foot automatically wants to push down when I shift, and if my left foot is poised over the brake pedal, I get a small pressure spike, even though I would swear that I never touched the brake. It is hard to overcome decades of reflex action.
So, check your brake pressure on upshifts if you are a left foot braker.
Matt Romanowski (01-12-2024)
Yeah, this technique also works well when heading for the start / finish line and waiting for the green flag to wave.
Rennlist Hoonigan
which cost no drachmas
The following 3 users liked this post by jerome951:
Basic Site Sponsor
Basic Site Sponsor
That wouldn’t be considered LFB because it’s not a braking event.
I concur with Peter's points in this thread. I am as good LFB (in cars where clutching is not needed) as I am RFB, but I know plenty of other fast drivers who never LFB. Neither is "better", IMO
ProCoach (01-12-2024)
Rennlist Hoonigan
Veloce Raptor (01-12-2024)
