Preparing for more power - advice?
#46
Peter
#47
Thanks Peter. Nice of you to offer some advice based on your own / real usage.
Kuhmo V730 tops out at 275/35/18 so that isn't going to work
Nankang CR-S does come in 255/35 and 315/30 for 18", so that is a good possibility (but USA stock looks low/none)
Bridgestone RE-71RS: I now see them listed on the Bridgestone site in 295/30 and 255/35 for 18", but I don't see the 295 at Tire Rack. That would be a good possibility.
Thanks!!
Thanks!!
Also compound trumps size every time. Those are words of wisdom many people forget.
Peter
#48
Replace the clutch. The clutch is relatively cheap.
The work is trivial when the engine is out.. Non-trivial once everything is put together.
With more power plus existing wear its worth considering.
My rule of thumb is to replace the clutch whenever the engine is out.
#49
Thanks!
#50
Thanks!
#51
Tires
Based on feedback in this thread, and some other web searching, here is what I found for tire options. I still need to run them past Paul at Radial Tire (my local shop) for his opinion and pricing. Wheels are 18". I have them roughly sorted in terms of my interest. Since Paul gets so much feedback from track drivers, I think he might be the deciding vote.
Bridgestone RE-71RS (200tw)
255/35 ($319 @ TR) and 295/30 ($386 @ TR) [$1410]
Nankang CR-S V2 (200tw)
255/35 ($351 @ Phil's) and 315/30 ($462 @ Phil's); both shown as out of stock but expected in August [$1626]
Yokohama Advan A052 (200tw)
255/35 ($347 @ TR) and 315/30 ($505 @ TR); stock in August and early Sept [$1704]
Nitto NT01 (100tw)
245/40 ($310 @ Discount Tire) and 305/35 ($405 @ Discount Tire); TBD availability? [$1430]
Nitto NT01 (100tw)
#52
Fyi i just had a set of nt-01 delivered by tirebuyer in those sizes last week for $1238. 10% coupon and no sales tax to DE. Its my 3rd set i have got this year. Look around they r out there. I get around 50 heat cycles and they dont fall off.
R they the fastest? No but when u stack, price and longevity into the equation they r hard to beat.
steveP911 (07-31-2023)
#53
OP,
Have you also checked out the RC1s from Maxxis? Not a fan of the v1s but supposedly the v2s were MUCH better and are a great value. Any RT660s available near your sizing? On your list of tires I don't think you can go wrong. How bout trying them all?? :-)
#55
Current (all used up) tires are RT660's. Previous set was Continental ExtremeContactForce. Slight preference to the Conti's over the Falken's.
Thanks.
#56
thanks
#57
TR is now a Nankang CR-S dealer and have some sizes in stock. Just got a set of 245/35 19and 295/30 19 for the GT4. Be advised they run wide on tread width. The 295/30 rear is ~12" tread width and 245/35 front is ~9.5" tread width. They are pricey though.
Peter
Peter
steveP911 (08-02-2023)
#58
Here is a listing of characteristics for the three tires I have used most recently (A, B, C) and the four new ones I am considering. Yellow highlighted cells mean there is conflicting data online. Otherwise, I think it is all correct. Most tires look fairly available except for the Nankang that seems to have had a shipping delay. Maybe there are others out there, but these are the best four I have found with sizes meeting my needs. Sorry if it is blurry. I can attach the Excel file if anyone wants it.
#59
Steve
TR tread width numbers are screwy at least in the 2 sizes I purchase. Looking at their tread width numbers it looks like the generic tread width numbers not actual measured numbers. Kangs run wide
Peter
Peter
#60
255/35: SW = 10.2, TW =10.2
315/30: SW = 12.6, TW = 12.4
Does this seem reasonable?
