Trailer Flooring Options?
I just bought a new 24' toy box.
The walls and ceiling are finished but the floor is bare plywood.
I was looking for advice and comments on what type of flooring to install.
Some I've seen are:
Diamond plate: nice but concerned about weight, cost, and practicality.
"Black Rubber": I've seen this at the track but not sure how is wears, cost, and where to find an installer.
Also I am going to install E-track along with the floor so that is a consideration
TIA
Some I've seen are:
TIA
I was going to recommend diamond plate, because a friend of mine put it in his 24 footer. It didn't seem to hard of a job, but I found out today, he got it real cheap because it had been cut for someone else, and they cut it too short. He got it very cheap, but he said it is super expensive if you have to pay retail.
I have carpet in mine, and it works ok, but usually looks awful because of oil leaks. It can't be swept, and has to be vacuumed out. But overall, I guess it is the best option. It looks good about twice a year, the start of the season, and after the one time I vacuum it.
Bill Seifert
1983 944 Race Car
1991 Pace 22 Foot Trailer
Bill Seifert
1983 944 Race Car
The plywood that I have seen in car trailers delaminates in two or three years if exposed to moisture. That being the case carpet, especially wet carpet, will accelerate this. My featherlite has plywood floor and ramp. The ramp has the initial signs of coming apart from the rain while the ramp is down. The paint with sand non skid mix is probably the most practical answer. The colored tile pattern glued down is more expensive but the best look.
Bill, if you are talking about the paint used for garage floors, that is what I intend to use. In talking to some folks this was their recommendation (none of them slept in a Holiday Inn however). The downside I have heard on the vinyl tiles is that a gas spill will dislocate them easily. A friend had a 5 gal gas can fall over and by days end, the entire floor had come up. What a freaking mess.
I was thinking about using one of those garage mats cut down to the right width and fastened with screws/washers. I was also thinking about laying 2 diamond plate runners in order to protect the mat from ripping when the car is tied down and the tires are full of rocks/etc.
Anybody see a reason why this won't work?
In the latest PitPal catalog (#15) on pages 66 & 67 they have several flooring options from RaceDeck: show tile $6 each, free flow illusion tile $2.99, fast deckfor $3.75 each and diamond tile for $4.25 each. All of these are 12"x12 snap fit tiles. On page 67 they show Hartman Flooring for $2.79/sq ft. They mention quantity discounts available.
The black rubber you're referring to, is it permanent or layed down like tiles??
...I've seen both.
The permanent answer is truck spray-in bedliner - of which I'm considering that option...the black rubber tiles, seen in gyms, etc. is a good removable, but pricey option. At least you can pull it up now and then to cleanup.
I have an acquaintance that had his trailer done in truck spray-in bedliner, I'm going to wait awhile to see how it looks with hot tires, travelling with the car sitting on it, etc.
I already have diamondplate pieces where my wheels sit...so I would imagine a good idea would be to screw them back down, over the truck bedliner, as I would think the bedliner would eventually wear through/peel up.
Diamondplate, as previously mentioned is DAMNED expensive if paying retail, I lucked out and got a 12ft. x 4ft. piece from a guy who had one leftover - $100
...I've seen both.
Jeff...the black rubber I am referring to is permanent.
Although I haven't had the chance to look at it in detail or ask anyone for details.
I looks durable, easy to sweep etc.
I have a picture if I can just figure out how to post...
