911 ignition coil heat shields for 981
#31
I just installed the heatshields from Suncoast along with new spark plugs and coils. The upper shield covers are easy enough to install but the lower cover's rear screws will not go in because of the catalytic converter. I fiddled and cursed that little bolt for almost an hour before deciding to drop the headers. You just need to lower the headers/cats just enough to install the screws. I am new to PCars so I was pleasantly surprised how easy it is to remove the headers. I might just drop the headers each time I need to replace plugs.
#33
The description can be confusing when ordering these because they're intended for the 911, installation is reversed on the 981.
9A1-104-311-00 upper US drivers side 1-3 (upper US passenger side 1-3 on 981)
9A1-104-312-00 upper US passenger side 4-6 (upper US drivers side 4-6 on 981)
9A1-104-313-00 lower US drivers side 1-3 (lower US passenger side 1-3 on 981)
9A1-104-314-00 lower US passenger side 4-6 (lower US drivers side 4-6 on 981)
900-385-041-01 8 Torx screws
