Reducing steering wheel load on a sports racer (or, why do I have sore lats?)
Had a great track day on Saturday with my Radical SR4. It's an old car, but I'm having a blast. Just installed a paddle shift system last week and was surprised that my install lasted all day and didn't require any fiddling!
I was out for about 1.5 hours over four sessions. Was about 1-2 sec under best time in first session, then set personal bests in the sessions 2, 3 and then 4 (the last session). Finally hit 1:09 on this track.
Suffice to say, I was running pretty hard (for me), the car was working well. I had a great day.
Yesterday, I was a bit stiff in the AM, I could tell my neck had a lot of work the day before, and my upper body was a bit tight/sore.
This morning, deep breaths are a bit painful on the left side, below the armpit and going around to the back below the shoulder blade. I think it's my left lat muscles and a bit of my scapula that is really sore from steering.
The track was NJMP Lightning which has a long (about 15 secs), high speed (Vmin about 88 mph) right hander where the wheel is really loaded.
For me, I find that this corner gives me the most workout throughout the whole track and I think most of my soreness/pain is from fighting the wheel as I'm turning right.
I feel there are a few obvious things I need to do:
But, on the car front, is there anything I can do to help reduce the steering force?
Would appreciate thoughts and advice on this...
Thanks,
John
- Work out / improve conditioning. I don't work out at all (49 yo, slim build) so I need to improve my core and I'll start working on this. I'm going to start with these (https://www.redbull.com/gb-en/motors...-racing-driver) since I don't want to make time for the gym. We also have a Concept 1 at home that I'll start working on.
- Work on balancing steering load between arms, so I'm not always just pushing up with the outside arm, but also pulling down with the inside arm.
- Caster -- I don't think I have a way to reduce front caster on my SR4, I'll double check, but I couldn't see anything obvious.
- Larger diameter steering wheel?
- Reduce steering ratio -- probably don't want to do this, not sure if the rack is changeable
- Power steering -- somewhat serious about this, but probably not feasible.
Thanks,
John
One thing to consider when steering wheel is how you're applying force. That is, if turning right, then right arm is pulling down versus left arm pushing up and vice versa.
That being said, I hear Radical's put a real hurting on your body, so you probably need to focus on conditioning. Sounds like a good pain!
Thanks Moose. I'm thinking the same thing.
Someone asked for a video, you'll see the long right hander at the beginning of the video here...
John
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
1) Shorten the upper control arm forward point
2) Lengthen the upper control arm rear point
3) Shorten the lower control arm rear point
4) Lengthen the lower control arm forward point.
Otherwise, adjusting any of the above points would be helpful. The goal would be to minimize the angle of the imaginary line that connects the upper and lower ball joints at the upright (when looking at the car from the side).
Hi John, Radicals are defiantly a physical experience that you need to work up to. The most fun way to get in shape is to drive it more.
An exercise program will help also. Your idea of balancing the load between arms is exactly correct. Also, in my Radical I found that my driving position allowed my left forearm (it is a left hand drive car) to touch the side of the cockpit and I could use that contact to have a little more leverage on the wheel while cornering. Also, Radicals typically have 255mm or 270mm round steering wheels, but many of the newer cars are using the optional Sparco F10A which is 310mm with an open top. The F10A has been getting very good reviews from drivers and provides a bit more leverage. Here is a link to a discussion on the topic.
https://radicalsportscarregistry.com...sr8/#post-1069
Charley
Charley
Basic Site Sponsor
Basic Site Sponsor
Received 3,219 Likes
Reducing caster will hurt low speed mechanical grip.
Work out, it's better for you!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Didn't realize that about the low speed mechanical grip, thanks Peter.
Charley
Charley
Basic Site Sponsor
Basic Site Sponsor
I have a lot of folks that I work with go to larger diameter steering wheels. Works well.
From an open wheel guy.
Working out helps but even when I've been in better shape my head and neck get sore after many relatively high g laps.
My steering feels heavy as well and my hands and wrists always get sore. Look at the pro racers when they are done with high g racing - their hands/wrists are sore! Indycars don't have power steering!
I'm a little concerned about the painful breathing on your left that you describe. If this hasn't started getting better you need to make sure you didn't crack a rib. Along those lines, is this discomfort being caused by your left side being forced into a hard or protuberant part of your seat? A custom seat insert does wonders for driving comfort and performance - I don't move a bit in my seat from my torso down to my knees.
Your car will give you a workout every time you drive it. In my formula car my HR is typically 140-150s. When I drive our Mx-5 Cup it's in the 110s.
Sounds like you are off to a great start in a really cool car!
Core strength conditioning is key. Also what really helps is holding a round barbell weight in front of you with both hands and "steering" it left and right. Strengthens grip, forearms, neck, etc
Rennlist Hoonigan
which cost no drachmas
If you want to explore power steering, look at DC Electronics EPAS. I don't have any experience with it, but they have been pushing it pretty hard for a number of years. http://www.dcemotorsport.com/Home/EPAS I believe it's essentially a European Ford Capri motor (I think it's a Capri) and their controller.
As everyone pointed out, you're better off working out. The workout you posted won't be enough. I'd suggest looking at the social media for Pit Fit and Podium Performance to see appropriate exercises. Pit Fit has a neck strength book, but I wouldn't recommend it (you'll find it all with a little looking). Building your core strength and neck strength will really help you in the car - far more than the power steering.
Yeah, get your *** to the gym already!
Do you know what your current caster setting is?
Also touched on, look at your ***-to-seat interface. You're gonna end up doing even more work if you're not well-secured in the set... and a generic race seat IMO isn't good enough for a car with this level of performance, consider a custom poured bead seat if you don't already have one.
