SOLD.... This Spec Boxster will take you straight to the front of one of the most competitive classes in PCA Club Racing. Fully compliant to PCA rules. Recent podiums and wins at Sebring, Road Atlanta, Watkins Glen, Mosport, Road America, VIR and Daytona. A consistent front-runner, this car is absolutely at the top of its game. Needs nothing but a better driver. No expense spared. Professionally maintained and prepared. Longtime owner is considering retirement after knee replacement surgery. $35K includes THREE SETS of powder-coated wheels, AIM Solo DL data and HD SmartyCam, and fresh Riviera Blue urethane paint.
--2.5L engine with IMS Bearing upgrade --Custom 1.75" Chromoly FIA roll cage --Low-mileage stock G86/00 transmission --Sachs racing clutch --Aasco Lightweight flywheel --Bilstein PSS9 coilovers --450/500 race springs --Fabspeed Race exhaust --Two-quart deep sump --External oil cooler --Transmission cooler --Power steering cooler --12V AGM sealed race battery --4-point rear sway bar --5-point front sway bar --Front/rear drop links --GT3 lower control arms --Third center radiator --AIM SoloDL data system & custom mount --AIM SmartyCam and adjustable mount --Digital rear-facing camera with auto start/stop --Superturismo GT3 Cup steering wheel --Rothsports quick release hub --X2 direct/powered MyLaps transponder --Centric slotted front brake rotors --ATE slotted rear brake rotors --Pagid race pads: Yellow-front, Black-rear --THREE SETS of powder-coated 17" Yellow Twist wheels --Mounted with Toyo RR race tires --Extended wheel studs --Teflon-coated stud nuts --TRS braided brake lines --GT3 brake air deflectors --Fresh Fulthane Urethane paint --3-point fire suppression system --2-point kill switch system --Current PCA and HSR log book --Center safely net --Lightweight fiberglass roof --BSR interior roof net (no arm restraints needed) --Sparco Pro ADV TS Halo seat w/sliders --Schroth Profi III-6 Hans harness --Numeric shifter, cables --Tarett shifter riser --Ecliptech shifter lights --Driver-side safety net --AeroCatch hood latches --Wide-view rear mirror --Parabolic blind-spot side mirrors --Frame-mounted transport hooks --Electric fuel drain system --Plumbed Cool Shirt system
--Windshield defrost fan --Waterproof car cover --Lexan door transport window set
Engine is STRONG. 195+ HP on the Dyno. Fresh oil and transmission fluid analysis reports.
Car is located in North Central Florida off I-75 near Ocala, approximately 100 miles north of Orlando and Tampa.
More photos here https://tinyurl.com/yxa8vhnw
