Wet sump and high G forces
Rennlist Hoonigan
which cost no drachmas
You can't add analog channels to any Solo product (Solo, SDL, S2, S2DL). You would have to move to different logger to be able to add analog channels.
Basic Site Sponsor
Basic Site Sponsor
Received 2,856 Likes
Which I'm suspecting will have to be replaced with an MXM when it finally kicks... if it ever does (been in there since '04)...
Basic Site Sponsor
Basic Site Sponsor
That's a long way away from analog inputs, for those of us without CAN. Like our 924 with an old but still tickin' (except for one internal sensor) MyChron3.
Yep, I’ve been selling a lot of MC3 and XG-Log replacements in the last year. Mostly due to the fact than those antiques won’t integrate GPS or the SmartyCam. But you’re covered with the DL-1!
I’ll make you a special deal on an MXm, when the time comes...
If you can spin it fast enough it will create low pressure in the crankcase. There's a good Racecar Engineering article on it from a few years back. I don't want to try and summarize it having read it long ago, but the simple take away was that a little bit of vacuum in the crankcase can yield overall hp increases. The low pressure below the piston and the high pressure in the combustion chamber ends up creating a net force increase to the crankshaft.
Basic Site Sponsor
Basic Site Sponsor
Dry sump pumps are way less parasitic than the old Aviad pumps, T&T.
The increased power comes from better windage and fluid control in the pan. With no need to carry as much in the pan, you have no resistance from the throws constantly thrashing through the oil, you can add scrapers to keep the oil from frothing and “roping” around the crank, et cetera. BIG difference.
While I’ve heard the negative pressure point, it’s not really adding any measurable power, especially on big motors, AFAIK.
You eliminate a lot of the pumping losses in the crankcase too (similar to how gun drilling a crankshaft promotes pressure equalization across the cylinder bays).
Sometimes I miss when I did this professionally. Rose colored glasses I suppose.
[QUOTE=BillNye;15844652]Also increases the ring seal and reduces losses from oil windage.
This assumes a windage tray is installed in the dry sump oil pan. The oil falls down in the same way and pattern whether it is dry sump or wet sump
The dry sump allows the engine roll center and cog to be lower, better for suspension tuning.
Maybe the engine produces more gross up with a dry sump BUT the dry sump has a minimum of three gear sets, one for oil supply and 2 for scavenging vs one for wet sump. Believe the HP to run the dry sump oil pump is such that the net HP at the fly wheel is less for a dry sump set up.
Dry dumps are to used lower the cog and roll center if the car and to improve engine reliability.
