NT01 pressure recommendations
What's the consensus for DE hot tire pressures on NT01's? Assume 80 degrees, sunny, warm dry track, on a NB 996 (235's & 275's).
Thanks.
Thanks.
I start at 26 cold and bleed down to 33 hot at all corners. I have thousands and thousands of laps on NT01's and this has yielded the most consistent, predictable tire characteristics.
Start at 25 cold and set 32/33 hot. This is on a 996 running 275/35/18 and 335/30/18
How much are you all starting at 25 bleeding off to end up around 33? On my 996tt if I start at 25 I end up more like 36/38 f/r. The tires (235/315) feel like they are rolling over at lower pressures.
I'm a little surprised at some of the suggestions to end up at the same hot pressures front and rear. With several other brands I've used on the 996 I've found 2-3 lbs more at the rear (hot) is optimal.
32/33 on 997rs
around same on my 964 in those sizes.
