Help with Valuation 1999 C2 track car
An opportunity appears to be presenting itself that I'd be interested in. Unfortunately, it would mean getting rid of the car that I swore I'd never get rid of... always works out that way.... These things are hard to put a valuation on - I know that I'll NEVER get close to the money I have in this...
I'd sell the car with the trailer as well - it's a Featherlite 3110 (I figure the trailer is $5.5K)... the motor is Charles Navaro from LNE personal motor that he built for his own car and never installed... I bought it when I lost my last motor. I know what the build cost....
Some specs on the car.. .
1999 C2 70K ish miles
Engine & Trans
Flat-6 / LN Engineering 3.8l conversion / Track performer Stage II – new build – I’d say 3k miles or less – 4 weekends)
Mahle Piston upgrade
Bilt Racing 2QT deep sump
160 degree stat
Under drive pulley
OEM 3.8l airbox
3rd radiator upgrade
Motorsports replacement 6MT
OS Giken LSD
Numeric Racing Shifter
Rennline 5” shift riser
Suspension
Tarett front and rear sways
RSS drop links
Elephant Racing LCA’s
GMG dogbones
Ohlins R&T coil overs
Probably some stuff that I’m forgetting
Chassis / Body / Wheels
Relatively stripped interior
Performance Friction PFC11 brakes
RS683 Fluid
RSS 930 Roll bar
OMP HTE-Carbon full halo drivers seat
OMP – WRC passenger seat
OMP steering wheel
OMP harnesses
18” OZ Challenge wheels with R7 Hoosiers 245/315
18” OZ Allegrita wheels with NT01 245/315
18” Apex SM10 (part of the Rennlist group buy) with NT01 245/315
Getty Design 60” Cup wing
Getty Design deck lid
DemonSpeed RS roof height uprights
OEM 996 Supercup front splitter
Joe Toth Canards
Rennline aluminum floorboards
OEM AC still functional!
Engine & Trans
160 degree stat
Under drive pulley
OEM 3.8l airbox
OS Giken LSD
Suspension
RSS drop links
GMG dogbones
RS683 Fluid
RSS 930 Roll bar
OMP steering wheel
OMP harnesses
Joe Toth Canards
Awesome car. Unfortunately it doesn’t appear to fit nicely into any PCA race class, which will somewhat limit your audience. My guess is it’s worth in the 45-50 range.
I misunderstood your posting
it looked as though you were considering buying this car
Kind of a buyer’s mkt for this stuff
i have a silver 99 c2 with no motor (thanks to Fabian roock) and it isn’t even worth pulling out of the shipping container to get running
A prospective buyer may want to see if there is a class of interest it will fit in. NASA could potentially be a good fit, but to calculate the Race or TT class, you'll need a dyno...go to the NASA web site for specifics, and the weight of the car with a driver and maybe 1/4 tank of gas, the amount of gas that would be in the tank after a race.
NASA races all over the USA...weight to HP is the key criteria for this Club.
And GTS5 is very under subscribed. I find 996 Cups more often in GTS4. 997 Cups are more common in 5 than 4 in the Northeast region, I use the term common very loosely. I think I remember seeing only 1 car in GTS5 last season. If the car can be detuned or ballasted down to GTS4 it will have somewhere to play in NASA. Keep in mind that NASA GTS is home to HUGE aero and wide meats; at least in the Northeast. Most of the BMW's in 4 and many in 3 run tires that start with a 3. Other regions may be less nuts.
Very sadly, this is worth more in parts. If you don't want to do that, I'd think about throwing any (running) motor in there, and sell the current motor.
I've got it listed now with the trailer... if it doesn't get any love - I'll part it... not ideal - but it'll be what it'll be...
