Compression Check on a 944
I helping a guy check out a 944 motor this weekend. It is a 944 with the 10.2 pistons. Does anyone have any idea what the compression should be? I know my motor (1987, 9.6 comp ratio motor in a 83 car) has around 155 lbs in each cylinder. So I would guess the 10.2 should be more, but I don't know how much more.
Any help would be appreciated,
Bill Seifert
1983 944 Race Car
1987 944S Race Car under const.
Bill Seifert
1983 944 Race Car
You gotta be kidding me. Of all the 944 racers there are that read this list, and nobody checks their compression. I check mine every year, to make sure I don't need a rebuild. I realise all you dudes that, like me, have a 1987 or earlier 9.6 compression ratio motor, that we can't answer the question. But some of you have to have a 88 or later motor, and some you should check your compression, to make sure the motor is still good. Please someone, answer this.
Bill Seifert
Bill Seifert
Bill,
I can give you fresh numbers on an 89 951S - comp & leakdown.
I'm with you on this - comp, leak and oil analysis are good early worning systems to prevent a grenade event. No better way apart from pulling the engine down. Good luck with the numbers - did you trY the 944 NA forum here?
