Need help with Aim MXP Pre-Calculated Gears for a GT4 CS
So i recently purchased a MXP from Aim for my 2016 GT4 Clubsport but having issues getting the gears to show correctly.
When I use the "Gear" channel it shows one gear higher than it is, I.E. when in 1st, it shows 2nd so on.
I called AIM about this and they said the best work around is to use the Calculated Gears but I am not sure what the values are since I can not find the gear ratios for the Clubsport online, only can find the GT4 gear ratios but I believe the Clubsport being a PDK does not have the same ratios but not sure.
Also need a couple other values I am not sure about wheel circumference and axle ratio... Any help would be greatly appreciated.
Thank you!
Thank you!
Basic Site Sponsor
Basic Site Sponsor
Received 3,340 Likes
Your AiM dealer should be able to help you with this after you enter the intermediate ratios.
The ratios I have are: 3.909 2.292 1.654 1.303 1.081 0.881 with 3.25 final drive
The tire companies (depends on the tire you use) have the wheel circumference (this is for the rear wheel). Pirelli 680, IIRC
The default timeout works fine and the ECU RPM channel name should be used. The speed should be set to GPS speed.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
I use the Michelin slicks.
A bit annoying looking at my videos now showing the wrong gears.
Do you know what I put for Axle Ratio, is that the final drive ratio 3.25?
Basic Site Sponsor
Basic Site Sponsor
Axle ratio is same as final drive.
Rennlist Hoonigan
which cost no drachmas
I've always had great success using the built in gear calculating. If it's a car that gets gearing changes, I leave gear off the dash and video and just do the math channel in analysis.
Yea that was what my Aim dealer was suggesting but I like between sessions to just pop in my sd card on the laptop and look at the video and knowing the correct gear I am in is helpful for me.
Rennlist Hoonigan
Yup. What I do different is instead of the precalc gear, I use the calculated gear that does it off speed and RPM. Same result though. Good luck!
I did the calculated gears on the MXP for the new car, and at one time it was working, but then when I changed my display it stopped.
Tried to do the reset multiple times but it wasn't taking it thus why I am on the pre-calculated route now.
Originally Posted by GT345
Yep had calculated for my previous car with my Solo DL 1/2 and it worked fine.
I prefer the pre-calculated set up, most users don't change gear sets. It has been frustrating for me to get "calculated gear" to work on occasion. As far as the correct displayed gear number goes, I'd just play with wheel circumference until the gear number is correct, assuming the gears and final drive are correct in your table (Peter's ratios look correct to me).
Basic Site Sponsor
Basic Site Sponsor
